Don't forget the cam! I stayed with the stock 360 cam when I changed to the 390 crank and 4v pistons, and it's not all that impressive. It has a lot of low-end torque, but that's all; when you romp on it above 25mph, it just doesn't set you back in the seat. I'm going to a mild performance CAR 390 cam this winter.
My Merc MPC shows the C6AZ-6303-B as a 1U 428 crank?
Must be an older than a 1969 parts catalog, cuz...
C6AZ-6303-B was later replacedbyC9ZZ-6303-B = 1UA 428 Crankshaft.
The problem with old parts catalogs is, the part numbers are also old.
Ford updates 10's of 1000's of part numbers every year, and before I post one single part number on FTE, I have to verify if the number wasn't replaced at some point.
Thankfully, I have all the catalogs on paper and microfiche slides to enable me to do this, for without the O-S-I (OBSOLETE-SUPERCEDE-INTERCHANGE) Catalogs, I'd be SOL on FTE!
I now have the super rare and next to impossible to find 1960's early 70's Master Cross Reference Catalogs (from Pasadena Ford-they never threw anything away!), which enables me to decode cylinder head ID numbers, and any other part, mechanical or body, that has an ID number on it.
Mine is a Mercury 65-72 1975 final edition. The 1UA SCJ 428 crank is missing the little balance weight on #4 or #6 (can't remember which one off hand LOL) counter the 1U and 1UB CJ both have. The 1UA used with the short capscrew LeMans rods put the counterweight on the nose with the SCJ crank spacer. Because of the added weight of the LM rods. This I'm sure you know. So that's odd they replaced the 1U number with the 1UA number. I'd think it would reference the 1UB instead? LOL!!
Boy I'll have to double check my book. I remember you telling me about all the number changes and the OSI catalogs. Good thing your here to keep it all straight!!
