360 Or 390 Crankshaft ?
I dont think I seen this question so here it goes ,,,Is there any casting marks to
figure if a crank is for a 360 or a 390 being the stroke is different for each ?
Thanks .
Oh and are there different casting marks to tell a 360 cylinder head from a 390 ?
Thanks .
To my knowledge, there is no difference between 360 heads and 390 head or 352 heads. They are the same.
The exception is '72 - '76 trucks; the FE was dropped from cars about '70, and in '72 the truck heads received a D2T designaton. Before that, they were a C*A designation, indicating a car design.
My '66 has C4AE car heads on it, for example.
The 360 crank is identical to the 352 crank, but the casting numbers will tell the difference in intened application.
You will need to check the casting numbers (or measure the stroke) to distinguish between 390 and 360/352 cranks.
Valves are all the same size, except 428CJ (C8OE?)
However, you are right, there is no "360" or "390" head. But the heads from different years ARE different, just not specificly a 360 or 390.
art k.
Pickup a copy of the Steve Christ book "How to rebuild big block Ford engines. This has most of the popular head, crank, block, rods etc.....casting numbers, specs and such. Keep it in the truck when you go "fishin" for parts for quick ID and specs. Just a thought. On ebay for $18.99 or any local/online book store can order it. Mustangs Unlimited sells it also. There are also a few places online with part and casting number info for the FE. Check out www.woodyg.com click on the Fairlane site at the top. Then once there scroll down to "FE big block engine section" and you'll see the links for all the parts. It's not a complete listing but good for most popular FE components. G.
05-10-2017 07:33 PM
Kalve
13
10-11-2010 09:52 AM
2t, 2ta, 360, 390, and390, big, block, casting, crankshaft, crankshafts, differance, difference, fe, ford, numbers
