2005 Explorer Blend Door Actuator???
Can anyone tell me if the blend door actuator is self calibrating on a 2005 with manual temperature control? If so, will disconnecting the battery make it calibrate when reconnecting the battery. I have the traditional click-click-click when I try to move to a warmer temperature. I pulled and pushed on the actuator motor and it moved to heat. Then I got the clunk-clunk-clunk when trying to go back to cool. Every time it clicks i hear a change in the airflow volume. Any help is appreciated. I have read all the heatertreater articles.
Thanks...Cold in Carolina
rexpedition99
11-29-2019 07:18 PM
Zareen Shahin
New Member Introductions
06-12-2016 08:52 PM
bradcdavis00
11-06-2005 01:56 PM
