Clicking Rear A/C Blend Door
I have a 2002 Explorer with the rear A/C option. I have the clicking sound described in the TSB below coming from the blend door in the rear.
Has anyone else had this problem and fixed it themselves? I’d like to know how you did it.
My truck is out of warranty unfortunately.
Thanks -Brad
Technical Service Bulletins Summary
Make: FORD
Model: EXPLORER
Year: 2002
Service Bulletin Number: 01126
NHTSA Item Number: 622673
Summary Description:
SOME VEHICLES EQUIPPED WITH THE MANUAL A/C SYSTEM MAY EXHIBIT A CONTINUOUS CLICKING NOISE FROM THE BLEND DOOR ACTUATOR WHENTHE BLOWER SPEED IS SET AT THE #2 POSITION AND THE TEMPERATURE CONTROL **** IS SET BETWEEN THE 12:00 AND 2:00 POSITION. *TT
Thanks -Brad
Make: FORD
Model: EXPLORER
Year: 2002
Stop by your friendly, neighborhhod Ford dealer & ask them to show you that TSB which will have instructions on how to fix tis. Or join www.alldata.com for only 25 bucks & you can pull the TSB up in your computer.
Well according to what you posted it is a service message and not a TSB.
Here are the steps to replace the bad controller. Just be carefull not to break the trim panels and make sure you have all the appropriate tools to do the job.
Removal and Installation
Remove the LH quarter trim panel. For additional information, refer to Section 501-05.
Disconnect the wiring harness.
Disconnect the electrical connectors.
Detach the electrical connector pin-type retainer.
Disconnect the vertical air duct from the auxiliary climate control housing.
Remove the bolt.
Remove the bolt.
Remove the nut and position the auxiliary climate control housing away from the quarter panel.
Remove the temperature blend door actuator.
Disconnect the electrical connector.
Remove the screws.
To install, reverse the removal procedure.
Remove the bolt.
Remove the bolt.
Remove the screws.
I have a 2002 Explorer that is experiencing this problem. I purchased the replacement Actuator. Can you please send me the instructions to Remove the Interior Panel. You reference it in your original note as Section 501-05
Thanks, Tom
Thanks, Tom
Remove the C-pillar trim panel. For additional information, refer to C-Pillar Trim Panel in this section.
Remove the door scuff plate.
Position aside the rear door opening weatherstrip.
Remove the trim panel clip.
Vehicles without third row seat
If equipped, remove the luggage assembly cover.
Remove the stowage compartment doors.
NOTE: Right side shown, left side similar.
Remove the stowage compartment assembly.
Position the carpet aside.
Remove the brackets.
Remove the bolts.
Vehicles with third row seat
Remove the third row seat. For additional information, refer to Section 501-10.
All vehicles
Remove the D-pillar trim panel. For additional information, refer to D-Pillar Trim Panel in this section.
Disconnect the power door lock electrical connector.
Remove the liftgate door scuff plate.
Remove the rear quarter trim panel.
And since you will likely ask about the C pillar
C-Pillar Trim Panel
All vehicles
Lower the rear door opening weatherstrip.
Remove the trim panel clips.
Vehicles with third row seats
Position the second row outer seats to the forward position.
Vehicles without third row seats
Remove the rear seats. For additional information, refer to Section 501-10.
All vehicles
Remove the lower safety belt anchor bolt.
Remove the trim panel.
Pull the lower portion of the trim panel outward to release the lower tab.
Pull trim panel downward to release upper tabs. Remove the trim panel.
And Since you will likely ask about the D pillar
D-Pillar Trim Panel
Remove the third row seat cushion. For additional information, refer to Section 501-10.
Remove the safety belt anchor bolt for the third seat strap.
All vehicles
Remove the liftgate opening weatherstrip.
Remove the rear upper headliner trim panel.
NOTE: Make sure that the quarter glass attachments are correctly seated at the beginning of the installation procedure.
Remove the bolts.
All vehicles
C-Pillar Trim Panel
All vehicles
All vehicles
D-Pillar Trim Panel
All vehicles
Replacing Rear Blend Door Actuator
These instructions for removing the rear trim panels were very helpful. I have exposed the rear climate control housing assembly, but am trying to figure out which bolts to remove so as to get to the blend door and actuator. There is a panel on the left top of the assembly held down by six small screws but I am unsure whether they need to be removed. I also found a larger bolt above the middle of the assembly apparently securing it to the side of the Explorer. Would appreciate advice on what further bolts I have to remove. Thanks a lot.
Dont know what year you have edmike, but if you have a late model it should only be 3 bolts and a nut securing the whole assembly to the side. remove or move out of the way the air duct and remove those securing bolts and then just pull the assembly far enough from the quarter panel to access the actuators. The one closest to the rear of the vehicle is for blend door. The other is for roof vent/floor vent control.
Rear Climate Control Actuators on 2002 Explorer
Dear Homer: I removed two bolts and a nut on my 2002 Explorer and successfully accessed and removed the two actuators. My only question now is whether I should replace both or just the blend door actuator, which seems to have been the one with the problem. I'm leaning toward both, so I don't have to do this job again for a looong time. What do you think? Thanks very much, Ed.
rexpedition99
1997-2006 Expedition & Navigator
12-02-2015 01:14 PM
