Help! one dead coil pack?!
Old Aug 18, 2008 | 12:21 AM
Kijutsu's Avatar
Kijutsu
Hi all. I have a problem with my '93 Ranger. The heater core hose popped right underneath the right coil pack and sprayed all over and I think it shorted out the coil pack. The truck died on my way to work tonight. By checking with a timing light, I get spark on the left coil pack, but nothing on the right. Also, I tried to pull the ECM codes and I get no check engine light whatsoever, no check engine light when I go to start the truck, that I hope is a dead light bulb. I also don't hear the fuel pump kicking in when I go to start the truck either. Do I have multiple problems? Or is one causing a ton of others?
I forgot to mention, I have an aftermarket tach wired into the ECM thru the tach line. The tach bounces around wildly while attempting to start the truck. If I disconnect the right coil pack, the tach does squat. Disconnecting the left coil pack, the tach still bounces around wildly.
--- EDIT ---
I'm wondering if I didn't lose my crankshaft position sensor? As I've read that it provides RPM info.
Old Aug 18, 2008 | 10:49 PM
trebor_9513's Avatar
trebor_9513
Ford computers are the hardest to get missfire check engine lights to come on. I would start with your crank sensor. BUT, the easiet route, Ohm out the know good coil pack, then ohm out the potential bad. Not the same, good indication that the coil pack is shot.
Old Aug 18, 2008 | 10:51 PM
trebor_9513
oh, yea. I would check on that non functional fuel pump first. check the fuses. With all that water flying around its possible something arc-ed.
Old Aug 22, 2008 | 01:46 PM
Kijutsu's Avatar
Kijutsu
Fixed it...
It was a bad grounding cable from the battery to what appears to be the computer, coil packs and ignition module. She's up and running again.
Army Ranger
23
Jan 19, 2015 08:08 PM
theran1986
3.8 & 4.2L V6
Nov 23, 2014 11:19 AM
explorerjwd
Oct 5, 2010 08:20 PM
acc7484
Electrical Systems/Wiring
Aug 11, 2005 10:22 AM
Cav
Aug 12, 2003 06:39 PM
