Front End Clunk
Old Nov 29, 2008 | 02:13 PM
Broken Wallet's Avatar
Broken Wallet
Front End Clunk
I have a 2000 Excursion I absoutly love this truck except I have a clunk or creaking sometimes when turning the steering. The truck has a 6" Pro-Comp lift and I am running 305 70 16 (33's) on 10" wheels. The truck has a new Drag link tie rods and I just replaced all 4 ball joints (they really needed to rest) I still have the noise has any one heard of the steering box making noises the steering feels tight but who knows between the mis and the steering noise I am going crazy HELLLLLLLLLLLLLLLLLLLLLLLLLP
Old Nov 29, 2008 | 03:07 PM
ExcursionAZ's Avatar
ExcursionAZ
I used some grease that I had from a poly bushing kit and greased the rubber bushings that hold the sway bar, was a 20 min fix. I was having identical symptoms (clunk when turning). good luck
Old Nov 29, 2008 | 03:35 PM
Broken Wallet
I don't have poly bushings but I'll try it. Thanks
Old Nov 29, 2008 | 05:05 PM
Cardiac69's Avatar
Cardiac69
Also, the 2 front body - to - frame mounts have a tendency to become very "dry" and need some silicone or anti-seize on them. Do a search in this forum under body mounts and it'll explain....
Old Nov 29, 2008 | 05:38 PM
Broken Wallet
those were replaced about a year ago by ford
Old Nov 29, 2008 | 06:34 PM
BAJI26's Avatar
BAJI26
OTT, how much did it cost to replace the body mounts and how many did you replaced? Thanks!
Old Nov 29, 2008 | 06:42 PM
rnolloth's Avatar
rnolloth
sway bar bushings are very common as are the sway bar links.
Old Nov 30, 2008 | 08:55 AM
Broken Wallet
had 4 body bushings replaced under extended warranty $50 bucks
sportsuburbangt
Mar 24, 2015 09:08 AM
jkrjlr
1997 - 2003 F150
Mar 24, 2013 12:21 PM
evilwayz7
2004 - 2008 F150
May 8, 2012 06:22 PM
RWilson
New Member Introductions
Sep 9, 2007 09:30 PM
cgoleye
Feb 3, 2004 08:48 AM
