Radiator/reservoir cap question
Old Nov 29, 2008 | 03:12 PM
Dakrri's Avatar
Dakrri
I had my radiator fluid tested at a local “quick lube” shop yesterday. The antifreeze was good, clean, and tested to 30 degrees below zero. However, he tested my radiator/reservoir cap and it would not hold 16 lbs of pressure. And I noticed that when you tightened the cap, it would “rachet” when it was tight, sort of like a gas-cap.
So I went to Autozone and bought a new 16 lb (pressure) cap and this one does not rachet, it just screws tight. And...maybe this is coincidental, but my trucks temperature doesn’t seem to have the warm-cool swing it use to have. If I have the temperature at 70, it blow very warm air, and I have to lower it to 67 to get what feels like, 70 degree air.
The temperature "dashboard gauge" is fine and stays steady at the halfway point.
Does anyone know if there is a reason for the rachet type cap versus the one that just screws tight?
Thanks Dakrri
Old Nov 29, 2008 | 11:51 PM
RACERX7775's Avatar
RACERX7775
the factory cap does ratchet. at least on my V10.
Old Nov 29, 2008 | 11:59 PM
weekendwarriorfsw32's Avatar
weekendwarriorfsw32
Master of Strokes
Same here on Both trucks.
Old Nov 30, 2008 | 08:11 AM
Supercab's Avatar
Supercab
Wink
I noticed the same thing when I bought a new quality STANT cap for my '99 F350....it just screws tight and thats it no racheting like the original...and if I tighten it ever so lightly is breaks loose and spins kind of like the thresds are bad....put the original cap back on and all is fine.....I think I'll just get a new cap from Ford????
Old Nov 30, 2008 | 10:46 AM
Dakrri's Avatar
Dakrri
I think I'll buy a new one tomorrow from Ford. Even if it doesn’t make a difference with the temperature swing, I’ll have peace of mind.
Dakrri
1ford1prowler
1947 and Older Ford Trucks
May 1, 2016 06:05 PM
GreenMM
43
Apr 21, 2016 09:15 AM
Mark Brooks
Modular V8 (4.6L, 5.4L)
Feb 15, 2016 01:33 PM
Fourwheelinj1
Apr 11, 2007 09:15 PM
wannabronco
13
Dec 11, 2004 03:47 PM
