intro - MN
Old Nov 28, 2008 | 11:02 PM
bigbird350's Avatar
bigbird350
intro - MN
I've never talked on the computer b4, I feel a little like a fish out of water. I hope to share some experiences along with picking up some pointers from others folks. It should be fun.
Old Nov 29, 2008 | 01:24 AM
Fomoko1's Avatar
Fomoko1
Welcome bigbird350, getting the hang of using a computer takes a little time but it will be well worth it. I`ve been there and if I can do it so can you.
Swing by your local MN chapter and check it out too: https://www.ford-trucks.com/forums/forum86/
Old Nov 29, 2008 | 12:58 PM
bigbird350's Avatar
bigbird350
heater problems
I have trouble getting heat out of 95 7.3 ford 350. This will be the second season without heat. When the water pump was replaced last year I had the system flushed and new thermostat replaced also. I take off the cover around the heater core and the heat is so intense that it will fry your feet yet I get nothing but luke warm air out the vents. I remove snow in northern Minnesota in an open cab bobcat. It would be nice to thaw out in the truck after a few hours out in the cold. I am in need of direction for some convection.
Old Nov 29, 2008 | 06:03 PM
Ultramagdan's Avatar
Ultramagdan
Got two forums for you to try out.
https://www.ford-trucks.com/forums/forum28/
https://www.ford-trucks.com/forums/forum61/
I think your problem is vacuum related.
Old Nov 29, 2008 | 06:23 PM
Fomoko1's Avatar
Fomoko1
Cool, your into Bobcats too?
I`ve got an 2008-S250, that`s the reason for my having two Louisville gravel trucks.
hotroddually
13
Apr 29, 2007 06:01 PM
chrono4
Jan 31, 2006 03:28 PM
FTE Herman
21
Nov 2, 2005 04:36 AM
Monsta
May 26, 2005 05:56 AM
sierraben
Jan 8, 2005 12:31 AM
