Patch panels are next
Old Nov 28, 2008 | 12:41 PM
reg1952's Avatar
reg1952
Should be able to start my fenders this weekend. Need to make some repairs on bottom of the fenders. I have a 4x4 sheet of 20 gauge sheet metal. Should I be using something a little thicker or is this ok?
Old Nov 28, 2008 | 01:27 PM
tip49's Avatar
tip49
metal gauge
I think the fenders may have been 18 ga or possibly 16 ? Only quessing. I used 18 ga for box fabrication, but I believe the original box was thicker. I have the front lowers to do on my 50 , mainly dents not rust.
Tom
Old Nov 29, 2008 | 10:32 AM
AXracer's Avatar
AXracer
Most of the body sheetmetal is ~ 18 ga. I like using something in that range unless I need to make something with a lot of shaping needed. The heavier metal gives you a little extra stock in case you get a little heavy handed with the grinder smoothing the welds, is easier to weld without blowing thru and less likely to heat warp. Be sure to use cold rolled sheet rather than hot rolled.
PS: a thickness gauge is an inexpensive and useful tool to have.
Old Nov 29, 2008 | 03:42 PM
Brian_B's Avatar
Brian_B
I ended up using 19 GA on mine. That is what I could get access too (for free). I am cheap..err..umm...frugal.
Old Nov 29, 2008 | 04:24 PM
reg1952's Avatar
reg1952
Thanks. I was to work on my patch panels today.But ended up doing Christmas decorations outside. Had some time left so I made up my steering column shaft instead. Maybe tomorrow!
armyaviation
Oct 24, 2012 06:05 AM
GreatNorthWoods
Jul 24, 2006 02:45 PM
David-ID1
May 23, 2006 09:22 AM
camo4stealth
51
Jan 31, 2004 07:00 AM
benschultz4x4
Jan 20, 2004 03:30 PM
