Sponsored by: Kumho
Tire Squeel
Old Apr 15, 2002 | 10:04 PM
raybrowne's Avatar
raybrowne
Tire Squeel
When making a turn at low 1st gear speeds(for example backing out of a parking spot), my truck makes a squeeling sound(I assume it's the tires). It is a 1988 Ford Ranger 4WD, other than the tires being worn out(I'm not sure if they are, I know the back ones are new) is there anything else that could be causing this?
Thanks,
Ray Browne
raybrowne(No Email Addresses In Posts!)
Old Apr 16, 2002 | 05:16 AM
Yeti's Avatar
Yeti
Tire Squeel
>Thanks,
>Ray Browne
Did it just start recently? you say the rear tires are new, could be a softer compound than the tires you were running. New tires somtimes squeal on fresh sealed blactop also.
Aslo, if you have limited slip, it could cause this also.
Old Apr 17, 2002 | 08:17 AM
Yeti's Avatar
Yeti
Tire Squeel
Old Apr 19, 2002 | 12:22 AM
71mustang's Avatar
71mustang
Tire Squeel
I think the sound is the power steering belt slipping. Does the sound happen mostly when the wheel is turned almost all the way one direction?
Cody
Old Apr 20, 2002 | 05:23 PM
aksniper's Avatar
aksniper
Tire Squeel
I'd bet ya the cost of a new belt that it is the belt. Only reason I know this is cause once in a while I loan my buddy my '96 Ranger to use and so I take his '95 Monte Carlo. Well anyways, didn't matter if I went slow through the turns or if I just dropped the gas pedal and took off as fast as I could through the turn, the squeal was there. Well anyways, he had the belt replaced and problem solved. Just thought I'd put in my two cents. Goodluck.
James
nbtone
22
Jul 17, 2020 02:30 AM
thecreative121
Jul 23, 2010 03:35 PM
wolfdog1
1997 - 2003 F150
Apr 19, 2005 07:16 PM
bronco 1996 16 year old
Jun 5, 2003 12:43 AM
Jeff Morrison
Apr 14, 2003 12:33 AM
