Violent Shaking
Old Jun 4, 2003 | 11:44 PM
bronco 1996 16 year old's Avatar
Unhappy Violent Shaking
I have a 1996 bronco with a 302 and a M5OD.
I have only one question. Why when i try to get the tires spinning does the axel push foward and spring back causing the whole bronco to shake violently. The tires will start to squeel but then the whole truck shutters. Why does this happen and what can be done to fix it?
Old Jun 5, 2003 | 12:39 AM
c_rossman's Avatar
c_rossman
Violent Shaking
I believe it has more to do with the manual tranny than the axle. I have a 1993 F-250 with 460 ZF-5Speed my rear end hops alot when trying to do a burn out, I have found that 3rd gear works the best in my truck for doing burnouts on freshly paved surfaces, got to leave the first mark! My cousin has the same truck with a E40D and he can smoke the tires till the cows come home. I believe it has something to do with the play in the drive train
Old Jun 5, 2003 | 12:43 AM
c_rossman's Avatar
c_rossman
Violent Shaking
Feathering the clutch helps. Everything that is fun is always hard on the clutch!!!
nwjones18
Sep 20, 2016 08:57 AM
powerstroker100
86
Nov 23, 2014 10:53 PM
85bronco
1978 - 1996 Big Bronco
19
Mar 29, 2013 09:53 PM
brcwelding
13
Aug 9, 2012 02:34 PM
stealth52
Aug 18, 2007 04:27 AM
