Squeeky Front End
Old Apr 13, 2003 | 08:05 PM
Jeff Morrison's Avatar
Jeff Morrison
Angry Squeeky Front End
My 97 Expeditions front end is squeeling like a stuck pig. The dealer and a tire store both tell me the joints are fine but its just the sealed tie rods making noise. Any one know of a spray lube or penetrating oil that I could use to quiet my front end that won't damage the joints? Thanks
Old Apr 13, 2003 | 10:02 PM
Racerguy's Avatar
Racerguy
Squeeky Front End
Hi Jeff Morrison and welcome to FTE
The most common places for squeeking in the front end are the idler arm, ball joints and tie rod ends in that order in my experience.
It's pretty hard to get any lube into any of the joints but you might be able to carefully pull the dust boot off and spray in some liquid grease like Ford Multipurpose spray grease or another one that is good is HoneyGoo but it's not always easy to find. Any sort of spray grease as opposed to oil might work...or it might not....just depends on if it seeps into the dry spot or not.
Replacing the tie rod ends isnt a really big job if you decide to fix it correctly
Old Apr 13, 2003 | 10:11 PM
Jeff Morrison
Squeeky Front End
Thanks Racerguy, I'll try the lube, replacing the front end seems to much though as theres no problem with it. A good buddy who just bought a 2003 has the same squeek, it's not a mechanical problem, just makes it seem like you don't maintain the vehicle. A little embarassing for guys who are maintenance freaks.
Old Apr 14, 2003 | 12:33 AM
MACH351C's Avatar
MACH351C
Squeeky Front End
I had the same problem. Slid a grease gun with a needle attachment up under the boot. Filled it up. Within a day, no more noise.
