Sponsored by: Innova
VSS wire 03 Screw
Old Nov 26, 2008 | 04:56 PM
79 Trailer Special's Avatar
79 Trailer Special
VSS wire 03 Screw
anyone know where to pick up the VSS on a 03 Screw with a 4.6L. Just installed a avic d3 but have not had any luck doing a search...Thanks in advance
Old Nov 26, 2008 | 05:11 PM
madsonp's Avatar
madsonp
Who makes the Screw ?
Old Nov 26, 2008 | 05:27 PM
ReAX's Avatar
ReAX
Screw= Supercrew. Hopefully using the term correctly means he has a 2003 F150 Crew Cab.
Try this, it's not the exact application, but might get you close.
SPEED SENSE gray/black instrument cluster or *4
*4 Also found at the radio on vehicles that have the in-dash CD changer
I might be wrong, but I believe the VSS is digital, so it will be a DC current that increases the faster you go. I can't remember well, but it's probably going to be low voltage, say in 1-8v range.
Old Nov 28, 2008 | 05:49 PM
79 Trailer Special
Well going on the grey/black wire idea, I found a second harness close to the radio harness and it had the right color so I gave it a shot. Seems to be working, just have to take her for a drive to see if its accurate. Thanks for the help.
mroth2008
Dec 28, 2013 07:18 PM
Billybob Bowhunter
Sep 22, 2012 09:11 AM
SBastow
Jun 24, 2009 08:54 AM
DJdemon6696
Aug 1, 2007 07:56 PM
buckethead5k
Dec 18, 2006 10:07 AM
