Sponsored by: Real Truck
cleaning vss
Old Jun 23, 2009 | 01:00 PM
SBastow's Avatar
SBastow
cleaning vss
What can you use to clean the vss?
Old Jun 23, 2009 | 11:08 PM
ReAX's Avatar
ReAX
The VSS should be a Hall Effect sensor which is encapsulated. So to clean the outside, use anything short of metal reacting acids. WD40, Gas, Diesel, 401, windex, what ever you like.
Old Jun 24, 2009 | 08:54 AM
Bear River's Avatar
Bear River
Former ******
However, if the Hall sensor is giving our false readings, while it is possible that outside effect are causing it (metal flakes or something), more than likely it means the sensor coil inside has experienced a dielectric decay. No amount of cleaning will fix it.
Dean06919
May 19, 2017 04:50 AM
BDR F250
Jan 31, 2016 08:48 PM
Krazee Matt
Jun 21, 2015 03:57 PM
erupert66
Oct 4, 2013 04:19 PM
Archimandrite
Aug 15, 2012 08:56 AM
