POSessed Expy HELP!
Old Dec 27, 2008 | 04:40 PM
MitchPeters's Avatar
MitchPeters
I just removed the fuse box. The 2 big square wire blocks that were bolted to the back of the fuse box are where my problem may be. Both blocks show moisture around the pins where the blocks plug in. I would guess that is the problem. Can silicone be applied around the blocks when I put them back in?
Old Feb 27, 2009 | 09:45 PM
dcline9's Avatar
dcline9
definetly the windshield. mine did same thing untill i had the gasket and glue replaced. it happens when it rains hard or for a long time.
Old Feb 28, 2009 | 06:18 PM
yookie413's Avatar
yookie413
Well i've posted a similar question awile ago and was quitepleased that madsopp answered my question and was right on about the problem.My expo was doing the same thing but worse things came along ie;the gauges started acting funky,the relay switches started clicking,the wiper would start working then not work at all,too much to list finally i went to a dealer and was told exactly what madsopp said there was a drip in the sunroof rainguard causing water to trail its way to my gem module located on or around the fuse box causing a short in the electrical system therefore sending the wrong signals.Anyway try to see if this problem exsist even when it does not rain or snow.I hope you don't have the same problem it's a hefty price tag i still haven't gotten mine fixed i just don't drive anywhere until i can find someone more reasonable than the dealer.
Cativo
Escape & Escape Hybrid
26
Nov 3, 2012 06:03 AM
Man_tlac83
27
Dec 10, 2011 12:55 AM
Gorilla1
42
Mar 2, 2008 10:05 PM
browneyz1968
Mar 11, 2006 10:45 AM
JEV
13
Oct 6, 2005 01:11 PM
