Sponsored by: Real Truck
Flashlight install
Old Jan 17, 2009 | 11:31 AM
  #46
GregsSD's Avatar
GregsSD
Here's a link with a good price on the Maglite that I use:
Buy Maglite® Mag Charger Rechargeable Flashlight System | Maglite RX1019 | flashlightz.com - Flashlights
It's so nice to have your flashlight always be fully charged when you need it!!!
Old Jan 17, 2009 | 11:56 AM
  #47
OnlyFords4Me's Avatar
OnlyFords4Me
So, does your charger shut off when the light is fully charged? I also found it here:
Amazon.com: MAGLITE RX1019 Heavy-Duty Rechargeable Flashlight System, Black: Home Improvement
Old Jan 17, 2009 | 12:38 PM
  #48
blueiron's Avatar
blueiron
Originally Posted by OnlyFords4Me
That's kinda what I was thinking. Most of the install pictures on this thread are mounted as though that is where they store the flashlight (on the charger). Do some of the chargers have on/off switches, or are you guys with the mounted chargers removing the flashlight when it is charged? Just contemplating my own install, that's all. Thanks!!
They don't have on-off switches. I merely remove mine when it is charged. Nickel-cadmium batteries will develop a 'memory' if used sparingly and charged up all the time. Streamlight and Maglite mention it in their instructions. I have used both flashlights at work every day, since 1984 and proper battery maintenance will give you a run time of about 90 minutes, instead of a lesser amount.
The new generation of LED flashlights demand less amperage, so they are less noticeable as the battery develops it 'set'.
Old Jan 18, 2009 | 10:04 AM
  #49
OSH4105's Avatar
OSH4105
Have any of you noticed a significant drain on your vehicle battery from your flashlight charger?
I have an 08 F-250 with a Stinger Survivor permanently mounted, If the truck sits for more than two days it wont start.
I ran down the battery a few times by leaving loads attached (sat radio, GPS etc...) The loads are now disconnected when I shut off the truck.
Now I know that after completely draining my battery 5 or 6 times in the last year its lifespan has been considerably shortened, but I dont want to put a new battery in the truck and have it last only a year.
I'm hoping that the problem is the weak battery and not an excessive load caused by the charger.
Any thoughts?
Old Jan 18, 2009 | 10:57 AM
  #50
WeWonIt's Avatar
WeWonIt
The charger draws very little and should not affect the life of your battery. I would take your battery's history in to account and have it tested, I bet it is on the low side of where it should be.
Old Jan 18, 2009 | 03:26 PM
  #51
juneau76's Avatar
juneau76
GregSD, I'm curious about this, too. Your post read as though it does shut off when it's done. Correct me if I'm wring, but you can swap the bulbs out for an LED bulb on any MAGLite, right?
Old Jan 19, 2009 | 12:58 AM
  #52
GregsSD's Avatar
GregsSD
My charging base has a led on it to indicate when it's charging. If you use the flashlight and snap it back into the charger, the led comes on, then after awhile the led goes out meaning that the flashlight is fully charged.
I have been using mine for 3 years now with no problems at all!!!
Here's a review on the maglite led conversions, it looks like they do not work with the rechargeable maglites:
Flashlight Reviews and LED Modifications
Old Jan 25, 2009 | 10:16 PM
  #53
1975StroppeBaja's Avatar
1975StroppeBaja
I'll play too, since I installed my regular Mag Lite today. Same spot that GregsSD used
Old Jan 31, 2009 | 04:57 PM
  #54
NorCalBusa's Avatar
NorCalBusa
Late to the party- but here's my Streamlight Stinger. I like it there- it's easy to grab and is always charged;
Old Jan 31, 2009 | 06:56 PM
  #55
shorebird's Avatar
shorebird
Here's my Maglight in its' charging cradle mounted for ease of access.
Old Jan 31, 2009 | 07:04 PM
  #56
NorCalBusa's Avatar
NorCalBusa
Dude- pop that sill plate and run that cord underneath. Rookie!
Old Jan 31, 2009 | 07:25 PM
  #57
shorebird's Avatar
shorebird
. Rookie![[quote=NorCalBusa;7082535]Dude- pop that sill plate and run that cord underneath/quote]
I know that you didn't call me rookie. The wire was left above the mat be cause the boss wanted it that way for now Heck he was upset that the mounting screws had to pierce the floor. Wait till he sees the new horns. https://www.ford-trucks.com/forums/8...s-warning.html BTW the wire is under the sill plate it is only above the vinyl floor-mat
Old Jan 31, 2009 | 08:01 PM
  #58
NorCalBusa's Avatar
NorCalBusa
Damn bosses- what do they know anyway?
Those horns look like a stock OEM replacement to me...
Old Feb 1, 2009 | 04:41 AM
  #59
redford's Avatar
redford
FTE Leadership Emeritus
If you're worried about Ni-cad memory, get a flashlight with Lithium-Ion batteries. They don't develop a memory.
Old Feb 1, 2009 | 08:55 AM
  #60
dkstuck's Avatar
dkstuck
Never thought flashlights would carry such a thread!
I still like my 99 cent squeeze throw away! Holds keys too!!
