Offroad & 4x4
Gumbo Mudder help
Old Nov 24, 2008 | 11:07 AM
mudder460's Avatar
mudder460
Gumbo Mudder help
I am trying to find a website that sells Gumbo Mudders and I have had no luck. Does anyone know where to order some from?
Old Nov 24, 2008 | 12:24 PM
Green Ford's Avatar
Green Ford
Gateway who made the Gumbo Monster Mudders was bought out a while back. From what I understand they are no longer making them. You may still find someone who has a set that wasn't sold or find used ones on different boards or e-bay.
Old Nov 24, 2008 | 01:53 PM
75F350's Avatar
75F350
Some stores still have stock on those antiques?
These would be old stock right? Wouldn't that make the tires a little crusty? When did these actually go out of production?
Old Nov 24, 2008 | 01:58 PM
Green Ford's Avatar
Green Ford
I think they have been gone a year or two. Yea I would worry about dry rot on them. I would make sure you see them brfore you buy them.
Old Nov 24, 2008 | 03:10 PM
mudder460's Avatar
mudder460
I did a search as well and found the same results. I did find the denman website and emailed them about the tires. I just didn't know if anyone might have known of anything. Looks like by the time I get around to affording them, they will all be gone. That really sucks cause I used to run the old Buckshot Mudders and loved them!
Old Nov 24, 2008 | 07:48 PM
mark a.'s Avatar
mark a.
Worst set of tires I ever owened.
Old Nov 24, 2008 | 08:57 PM
teds74ford's Avatar
teds74ford
I like them for their old school look.
Old Nov 25, 2008 | 01:46 AM
GregsSD's Avatar
GregsSD
I used to run 40" Gumbo Mudders years ago and loved them, but I wasn't to worried about the highway ride back then!!!
Old Nov 25, 2008 | 08:25 AM
mudder460's Avatar
mudder460
Mark, please go into detail. I am not really worried about the ride either. This isn't my daily driver or anything. I am pretty much just wanting something different from the normal swamper. I like to be different!
Old Nov 25, 2008 | 10:09 AM
75F350's Avatar
75F350
I was never a fan of the Gumbo Monster Mudder. Well, let me define that. I was a fan when there were maybe only a couple of tires available in the 40 plus size range.
The tire design of the past is an old design. These tires flat spotted worse than any swamper I have ever owned, and the noise was crazy. Having symetrical lugs made these things really sing. The sidewalls were stiff but weak. Sidewall punctures were common, and with a rather rigid sidewall even 15" tires popped beads. Heak, dont even think about running these old mudders at low tire pressures and having a 16.5" wheel. I think I could kick one right off of the wheel.
With such new tire technology out there, using an old style tire seems a little odd. Newer style and designs just work better.
Old Nov 25, 2008 | 10:49 AM
mudder460's Avatar
mudder460
I have always been a fan of Hawgs. I never had the money to buy Haws but I have owned a few sets of RVT's and I know they worked great for me. They were my second choice to run if I couldn't find Gumbo's. I will most likely get them instead of the Gumbo's since they are no longer produced. I was just wondering if they still wear as good as they used to since they were sold to Interco.
Old Nov 25, 2008 | 11:25 AM
mark a.'s Avatar
mark a.
What 75f350 said, (Ed). I'd add the set I had was so far out of round they were literaly tearing my truck up & flat spotting was real bad too. I had to greese the tre's every time after it drove it. Maby I just got the bad set & I'm glad they aren't on the market anymore.
Old Nov 26, 2008 | 11:21 PM
iggybob44's Avatar
iggybob44
I had a set of directional traction tread Bias-ply's in 7.50-16 size on a 1966 International 1200 4x4,they had symmetrical lugs,and suffice it to say,i needed higher wattage for my stereo's amp to drown out the noise at highway speeds. I see and hear a fair number of swampers in my area(even though im not near any real mud for the most part)and none of them make the noise that those old tires did.
79F250isalive!
Feb 22, 2015 04:25 PM
superswamper
Offroad & 4x4
Jan 30, 2004 11:58 AM
chadrock
23
Nov 11, 2002 07:25 PM
chadrock
Offroad & 4x4
Feb 22, 2002 09:12 AM
stuart
Jun 21, 1999 01:52 PM
