Truck headers?
Old Nov 26, 2008 | 11:45 PM
86stepsideF150's Avatar
86stepsideF150
Ok, good, so they will be happy down there. I can buy a pair of reducers with bungs for the sensors. That would be the easiest route. I also might even install new O2 sensors while I'm at it.
Old Nov 27, 2008 | 07:53 AM
Conanski's Avatar
Conanski
Have you seen my pics? Don't buy Flowtechs they make installing the rest of the exhaust difficult because the header pipe is too long and hangs too low. O2 sensor is no problem, drill a hole in the collector and weld in a bung. If the cable doesn't reach just strip it out of the harness and it'll reach.
New Exhaust - a set on Flickr
Old Nov 27, 2008 | 11:37 PM
Franklin2's Avatar
Franklin2
You should be able to get a set of shortie headers that have the O2 hole already in them. And they would fit better than the long tube headers.
Old Nov 30, 2008 | 05:53 PM
86stepsideF150
Shorties are more expensive though, and despite the fitment issues, long tubes perform better. I guess I'd rather go with the long tubes to save money.
Old Nov 30, 2008 | 09:15 PM
Franklin2's Avatar
Franklin2
How much are the O2 reducers and the pipe and clamps going to cost to hook the long tubes up? I believe the shorties will bolt right up to the exhaust you have now. You won't notice any performance difference shorties vs long tube in a truck.
1980 Ford F-250
Exhaust Systems
Dec 22, 2011 06:31 PM
MR-HI-BOY
Dec 10, 2010 11:23 AM
79f150TX
Jan 22, 2007 02:35 PM
Unimog005
15
Nov 10, 2006 10:20 AM
phatpony
Mar 30, 2005 12:31 PM
