I have a 95 f250 powerstroke 4x4 automatic and i have a few ?'s. When i start the truck it takes 30min of warm up before it will even move...never had any problems with it in the past. Good runner and it all of a sudden did this. It will blow black smoke for half an hour but idles good. IF u try to give it throttle it gets alittle over 1000 rpm and bogs like its not getting any air. If i shut if off then start it again it gets alittle better. Cam sensor has ben replaced and im outta ideas....just runs like an ol gasser if its not getting proper air when u hit the trottle....ideas please and much thanks
exhaust back pressure valve?...what affect on the warmup does that make?...and also the thermostat..never thought of that...it just wont go high idle forever and the smoke is rediculous
The EBPV keeps the exhaust gases from escaping raising combustion temps. They have a tendency to stick or stay closed longer than they should. Normal operation allows them to remain closed until a certain oil temp is reached, or the exhaust gas pressure overrides the valve.
I'd start by checking the EBPV and making sure its moving, however, it sounds like it's doing its job by your description.
Fuel filter is a good thing to inspect as well when diagnosing a hit and miss problem.
The T-state good very well be open aswell. These engines have amazing cooling capabilities and if the stat is not closed it will literally take forever to warm up.
thanks ive been here before i was 460man but was inactive for a while and couldnt get on my account...the valve is already unplugged so im lost...ive checked everything...sorry if im missing something
Doesn't sound like you have aftermarket gauges, but what is the engine temp when it's bogging down... I guess what I'm asking is that you believe that the engine is actually somewhat close to operating temp before you drive it.
