Warmup Problem!!
Old Nov 23, 2008 | 05:56 PM
fe390man's Avatar
fe390man
Warmup Problem!!
I have a 95 f250 powerstroke 4x4 automatic and i have a few ?'s. When i start the truck it takes 30min of warm up before it will even move...never had any problems with it in the past. Good runner and it all of a sudden did this. It will blow black smoke for half an hour but idles good. IF u try to give it throttle it gets alittle over 1000 rpm and bogs like its not getting any air. If i shut if off then start it again it gets alittle better. Cam sensor has ben replaced and im outta ideas....just runs like an ol gasser if its not getting proper air when u hit the trottle....ideas please and much thanks
Old Nov 23, 2008 | 06:13 PM
WALJON's Avatar
WALJON
Maybe it,s time for a new thermostat? I put a 203* thermostat in my truck and it sure made a difference.
the bogging your talking about sounds like your exhaust back pressure valve
Old Nov 23, 2008 | 06:18 PM
WALJON's Avatar
WALJON
Check this out http://www.google.ca/url?q=http://ww...m4EH_hKUd_kbPg
Old Nov 23, 2008 | 06:21 PM
fe390man's Avatar
fe390man
exhaust back pressure valve?...what affect on the warmup does that make?...and also the thermostat..never thought of that...it just wont go high idle forever and the smoke is rediculous
Old Nov 23, 2008 | 06:50 PM
c00nhunterjoe's Avatar
c00nhunterjoe
check the back preussre valve rod, it may be stuck closed
Old Nov 23, 2008 | 06:57 PM
fe390man's Avatar
fe390man
righton but what difference would that make after it runs right sort of...always seems like there is a hit and miss while driving it now to
Old Nov 23, 2008 | 07:03 PM
WALJON's Avatar
WALJON
I did a search for you read this
https://www.ford-trucks.com/forums/7...highlight=ebpv
Old Nov 23, 2008 | 07:05 PM
WALJON's Avatar
WALJON
I,m sorry I didn,t read your first post correctly I thought you had said it took your truck 30m to warm up as in coolant temps.
By the way welcome to FTE!!
Old Nov 23, 2008 | 07:21 PM
FARM69's Avatar
FARM69
The EBPV keeps the exhaust gases from escaping raising combustion temps. They have a tendency to stick or stay closed longer than they should. Normal operation allows them to remain closed until a certain oil temp is reached, or the exhaust gas pressure overrides the valve.
I'd start by checking the EBPV and making sure its moving, however, it sounds like it's doing its job by your description.
Fuel filter is a good thing to inspect as well when diagnosing a hit and miss problem.
The T-state good very well be open aswell. These engines have amazing cooling capabilities and if the stat is not closed it will literally take forever to warm up.
Old Nov 23, 2008 | 07:27 PM
fe390man's Avatar
fe390man
thanks ive been here before i was 460man but was inactive for a while and couldnt get on my account...the valve is already unplugged so im lost...ive checked everything...sorry if im missing something
Old Nov 23, 2008 | 07:58 PM
FARM69's Avatar
FARM69
Doesn't sound like you have aftermarket gauges, but what is the engine temp when it's bogging down... I guess what I'm asking is that you believe that the engine is actually somewhat close to operating temp before you drive it.
I would check the t stat.
Old Nov 23, 2008 | 08:30 PM
WALJON's Avatar
WALJON
Maybe the valve is closing by itself maybe it is broken and flapping around check to see if the rod is connected to the valve still just a thought
Old Nov 23, 2008 | 09:08 PM
97-psd's Avatar
97-psd
even if you have the EBPV unplugged it can still close, causing problems, you can tie it open as a short term fix to see if it helps your problem
