I had a fuel leak last week. It was coming from the banjo bolt on the back of the fuel pump. It takes a 1' 1/4" 12 point wrench to get in there and tighten it. I hear they come loose often. Could also be the fuel bowl. Check out this thread:
It can be leaking from quite a few places but it's Probably a fuel pump. You'll need to clean up the valley really good. Start it up and see where it's coming from.
Yes.. did that.. center area of intake manifold..
Will let a Tech go from here.....
