Steering pulling side to side
Old Nov 21, 2008 | 09:59 PM
fuelboy001's Avatar
fuelboy001
I have a 05 F350 and driving home tonight the truck starting pulling hard from side to side after turning a corner. I turned the corner and the steering wheel only came back so far and keeped pulling to the right and then I pulled the steering wheel to the left and the truck darted hard to the left and back and forth until I stopped.
I had the front end looked at by my mechanic and everything in the front end is tight and wouldn't reproduce the problem on the rack. So I started driving home and it started all over.
Thanks for any info in advance.
fuelboy
Old Nov 22, 2008 | 07:03 AM
bismic's Avatar
bismic
Did they check the "Stabilizer Bar" (or sway bar) end links?
Old Nov 22, 2008 | 08:06 AM
fuelboy001's Avatar
fuelboy001
Yes he did. I called a front end/frame specialist this morning and he is going to look at it. He says it may be the power steering pump or even the gearbox.
Old Nov 22, 2008 | 09:09 AM
69cj's Avatar
69cj
Sounds like the hydro-boost unit.
Old Nov 22, 2008 | 11:45 AM
jxdrl's Avatar
jxdrl
my truck did this and it was the axle end u-joints, behind the wheels. my passenger side one was frozen.
Old Nov 30, 2008 | 08:51 AM
pile_53574's Avatar
pile_53574
Yep mine did same thing, greased the axle u-joints(the only serviceable ones on the whole truck) and problem fixed
Old Apr 29, 2010 | 03:59 PM
2006lariat's Avatar
2006lariat
[quote=fuelboy001;6797413]I have a 05 F350 and driving home tonight the truck starting pulling hard from side to side after turning a corner. I turned the corner and the steering wheel only came back so far and keeped pulling to the right and then I pulled the steering wheel to the left and the truck darted hard to the left and back and forth until I stopped.
Well what was it? My truck just started this too!
andydunks
Jun 19, 2014 09:57 PM
volthause
Dec 17, 2012 08:35 AM
johnbox
Sep 7, 2009 09:59 PM
bre
Nov 8, 2004 04:55 PM
shadowcaster
Feb 14, 2004 12:28 AM
