Turning Radius
Old Nov 25, 2008 | 01:37 PM
  #46
Bergerson's Avatar
Bergerson
Originally Posted by ggirten
The backside of your tire isn't hitting anything is it? The only thing I can think of right now would be the gearbox itself.
must be the gear box, nothing else is touching, still about 2" from the spring pack, and the tire is not rubbing on anything else,
Old Nov 25, 2008 | 01:39 PM
  #47
NS F250's Avatar
NS F250
Originally Posted by Bergerson
I compleatly removed my steering stabilizer, made no differance, i thouht that it was limiting the travel, it was not, I am still a good 1-1/2" from hitting the bump stops on the spindle now, but it just wont turn that far, something else is stoping it.. Dam'd if i can figure out what???
This may be a stupid question, but did you turn the wheel both ways? Is it the same on both sides?
Old Nov 25, 2008 | 01:48 PM
  #48
Neil64's Avatar
Neil64
Pics
I'd love to see pics of what is being cut.
Thanks..
Neil
Old Nov 25, 2008 | 01:51 PM
  #49
Bergerson's Avatar
Bergerson
yes I did turn it lock to lock both ways, ??? even jacked up the front axle...
Old Nov 25, 2008 | 01:53 PM
  #50
ggirten's Avatar
ggirten
Thanks..
Neil
Look at Geoff240ti pics. The second one shows a tip stickout out about 2". This is the bump stop.
Old Nov 25, 2008 | 01:54 PM
  #51
Geoff240ti's Avatar
Geoff240ti
Thanks..
Neil
Neil
You can see here the bumpstop that is being cut..
I haven't cut mine yet.. still a bit nervous about it.
Old Nov 25, 2008 | 01:56 PM
  #52
Bergerson's Avatar
Bergerson
that is exactly what i cut, I cut off about an inch off each side... now it dosent even come clost to touching..
Old Nov 25, 2008 | 02:26 PM
  #53
03_PSD's Avatar
03_PSD
great pics Geof240ti, really helped to understand whats being cut here!
Old Nov 25, 2008 | 02:28 PM
  #54
Bergerson's Avatar
Bergerson
hope this works.....
Tire from spring pack,
Cut about an inch off
Turned all the way, not even close to touching the bumb stop
Old Nov 25, 2008 | 02:36 PM
  #55
03_PSD's Avatar
03_PSD
hope i'm not the only one that cant see those pics Bergerson
Old Nov 25, 2008 | 02:44 PM
  #56
Bergerson's Avatar
Bergerson
sorry I guess I don't have enough posts to post pics.. I put in the links to the pics.. Sorry
Old Nov 25, 2008 | 02:46 PM
  #57
superduty4x4's Avatar
superduty4x4
You can post pics, you just didn't do it quite right.
To post a pic, it needs to be in the following code:
(img)URL for pic (what you posted above(/img)
The only difference is, you need to replace the () with []. Does that make sense?
Old Nov 25, 2008 | 02:49 PM
  #58
Bergerson's Avatar
Bergerson
I think so, thanks I'll give it a try.... CHIT! still dosent work... right click pic and click show image
Old Nov 25, 2008 | 03:27 PM
  #59
Stewart_H's Avatar
Stewart_H
That doesn't work.
I did some testing on another forum, without going to the web address for the picture, and the picture didn't show. I think that website where you have the pictures hosted, doesn't allow direct hot linking to pictures.
Using the web address, if you go directly to the site and view the pictures, it will then be cached on your hard drive and it will show here in the forum, but without going to the address first, you won't be able to see the pic unless you host it at a different site.
Just put it in your Gallery here on FTE.
Stewart
Old Nov 25, 2008 | 03:57 PM
  #60
Bergerson's Avatar
Bergerson
One more time.... Sorry... and thanks Stewart
Tire from spring pack...
Tire from spring pack rear...
Cut off about an inch...
Not even close to touching....
