Turning Radius
Old Nov 22, 2008 | 08:17 AM
bfife's Avatar
bfife
still plays with trucks
the old body style truck were terrible about turning radius. we called my 97 1 ton crew cab long bed the "go around truck" cause you didn't turn around anywhere, you "go around the block" to get there. that being said, my 02 F550 crew cab xlong bed, will easily turn within the same radius as my fathers crew cab short bed chevy(spit). love that commercial axle. Barney
Old Nov 22, 2008 | 09:00 AM
ggirten's Avatar
ggirten
Originally Posted by duallydan
My 22.5 Alcoa's rub the springs without cutting the bumpstops. You want to see a rough turning radius.....
I have 285's on my truck with a shackle lift in the front. I didn't have any clearance problems before and I have just a little rubbing on the rear of the spring now, but the turning is much better. I did this on a 78' Chevy I had 20 years ago and it made a big difference without any problems, but I had 4" lift with 4" body lift with 36.5" tires.
Old Nov 22, 2008 | 10:57 AM
duallydan's Avatar
duallydan
My tires are 36" tall, no lift.... big problem with turning. We had to hack out the inner fender wells to make it work..
Old Nov 22, 2008 | 10:59 AM
87 F-150 I6's Avatar
87 F-150 I6
I was just thinking of this last night, with my old truck I could easily park next to somebody, turn around in the street. Now I park out, need to pull into somebody's driveway and back out to turn around. Good idea, keep us posted.
Old Nov 22, 2008 | 07:19 PM
Bergerson's Avatar
Bergerson
Where and what did you cut? I havent gone out and looked at mine yat but I am going to do this tomorrow if i can get away with it, I remember looking at my tires in relation to the spring pack and it looked like i had about an inch and a helf before they would rub...
Old Nov 23, 2008 | 11:13 AM
Bergerson's Avatar
Bergerson
went out and looked but I still cant figure out what it was that you cut.... call me stupid... I would like to do this today, it is a majior PITA to back up my 34' tralier into the slip next to the house, used to whip it right in there with my Dodge, but this thing is crazy.... any help would be appreciated, thanks
Old Nov 23, 2008 | 11:57 AM
Mike F250's Avatar
Mike F250
a friend of a friend is an engineer at Ford. He recommended this to me when I purchased my truck. Still on the to-do list...
Old Nov 23, 2008 | 02:15 PM
UP_There's Avatar
UP_There
That is good to know, sounds like it's not going to hurt anything if it's done RIGHT. My question is.......why didn't he "engineer" it in the first place?
Old Nov 23, 2008 | 03:46 PM
ggirten's Avatar
ggirten
They are made on the spindle and stick out about 2". When you make a sharp turn they contact the axle housing. This keeps it from turning any sharper. When you shorten these, they allow you to turn tighter. Just 1.5" has made a much tighter turning radius. I have driven all weekend and don't see any problems. The wifes ABS control unit went out of her van. No brakes at all, so I can't work on mine for a while until I get her going again.
Old Nov 23, 2008 | 04:13 PM
Bergerson's Avatar
Bergerson
Thank you, I see what you are talking about now, mine donot touch, they come close but do not touch, looks like my steering stablizer shoch limits them from ouching, I am going to pull it off one end and take a look now....
Old Nov 23, 2008 | 04:59 PM
Bergerson's Avatar
Bergerson
ok, I jacked up front end, took off steering stablizer, cut off 1" from each stop... no diff.. tires still stop about 2" from touching spring pack... almost seems like ps pump stops, i can hear it bog down if i try to go any further, but it wont go... ? ??? Now I am confused... dosent take much.. but this one has got me.
Old Nov 23, 2008 | 06:10 PM
ggirten's Avatar
ggirten
Not sure about that. My power steering pump doesn't have any issues. The ones you cut are on the front of spindle right? Could be the difference on my early 99' are your 00. My son has a 00' F350. I'll try to take a look at it.
Old Nov 23, 2008 | 06:19 PM
  #28
Bergerson's Avatar
Bergerson
yes they are on the front of the spindle, about 3" long, I cut about an inch off. now they dont even come close to touching...
Old Nov 23, 2008 | 07:35 PM
  #29
twags6's Avatar
twags6
Originally Posted by miller_feed
This sounds like a good thing to do. What are the drawbacks if any? Is it putting something else in a bind? I would like to know more about this.
I wonder how the front u-joints would feel after this mod. Mine already knock when I turn 3/4 of the way left or right.
Old Nov 23, 2008 | 09:02 PM
  #30
Stewart_H's Avatar
Stewart_H
Stewart
