Turning Radius
Old Nov 24, 2008 | 05:51 PM
  #31
firemediceric's Avatar
firemediceric
I guess the coil springs on the 2 wheel drive present a little differently than the leaf springs on the 4x4. On my truck, when the wheel is turned hard the bottom shock mount bolt is barely missing the brake caliper. If the wheels were to turn any sharper the caliper would contact the bolt.
Old Nov 24, 2008 | 06:06 PM
  #32
twags6's Avatar
twags6
The 2wd's already have a better turning radius due to the coil springs (no leafs to get in the way). Thats how the newer trucks are able to turn sharper.
Old Nov 25, 2008 | 06:51 AM
  #33
firemediceric
I can't comment on the turning radius of the 4x4 Vs. the 2WD, but I do know that with all the U-turns I end up doing in this jerk water town due to the traffic engineer's poor planning, I always jump the curb and go up on the side walk. It's a riot to see the scared look on the faces of the people holding soliciting signs on the intersection corners.
It's at those times I really appreciate driving my old Mercedes which turns on a dime. I hate to say it, but the turning radius is the one item my wife always points out when boasting about her Suburban Vs. my PSD. I have to admit, in this area the Suburban puts my PSD to shame.
Old Nov 25, 2008 | 08:31 AM
  #34
Geoff240ti's Avatar
Geoff240ti
I took a look yesterday on my truck (03 F350 4x4) and the bump stops definitely limit the turning. I REALLY want to increase the turning radius, but I'm mainly worried about the U-joints and the stabalizer. The stabalizer looks like it's almost at the end of its travel as it is..
So is this going to be a u-joint killer? I won't be WOT at full lock anytime, but I will be turning tight often since my job requires me to back the trailer into some funky spots. Something tells me if they did it from the factory there was a reason for it, but they maybe were being on the extreme safe side?
Old Nov 25, 2008 | 08:38 AM
  #35
NS F250's Avatar
NS F250
The coil sprung '05 and up trucks have about a 5 foot tighter turning radius, and the F450 and 550 have an economy car like turning radius. I wonder if the '99 to '04 U joints are much different than the '05 and up ones? I am also very interested in this thread, as the turning radius (and sloppy steering) is my biggest complaint with my truck.
Old Nov 25, 2008 | 08:52 AM
  #36
Geoff240ti's Avatar
Geoff240ti
Very Interesting.. We have some 08 F-250s here at work I can crawl under and take a look..
Old Nov 25, 2008 | 08:54 AM
  #37
ggirten's Avatar
ggirten
My son has my truck right now because his is down for PCM repair. I will do some testing this weekend in the turning radius of my truck versus his 00'. My nephew also has a 99' so we can test his also. Both of theirs are unmodified. I will also try to get pictures.
Old Nov 25, 2008 | 09:23 AM
  #38
03_PSD's Avatar
03_PSD
subscribing to see the results and maybe yet another mod
Old Nov 25, 2008 | 09:53 AM
  #39
superduty4x4's Avatar
superduty4x4
Definitely interested... I think my old 95 F250 super cab long box turned tighter than my SD does... the SD could use some love in the turn radius department for sure.
Old Nov 25, 2008 | 10:07 AM
  #40
DemonRace6's Avatar
DemonRace6
Hi!
subscribing and wondering if I got rims with a deeper offset if I could cut even more off of theses?
Old Nov 25, 2008 | 10:45 AM
  #41
Geoff240ti's Avatar
Geoff240ti
The 08 F250s are definitely alot different. Of course, this is to be expected when running coil spring vs leaf. Anyway.. they still have the very same U-joints as far as I can tell, so I can't see those being an issue with our older rigs.
The only thing left in question to me is the steering stabalizer. Mine is leaking oil so I'll probably upgrade right away, but as long as they allow the extra travel I don't see why any of this would cause a problem. I only have about 2" at most till I'm rubbing the leaf spring, this is my only issue. If I ever went to a larger tire, it would probably rub for sure .
Old Nov 25, 2008 | 11:58 AM
  #42
NS F250's Avatar
NS F250
How does the steering stabilizer on the '08 look? It must have a longer stroke than ares, maybe it will fit.
Old Nov 25, 2008 | 12:38 PM
  #43
Bergerson's Avatar
Bergerson
I compleatly removed my steering stabilizer, made no differance, i thouht that it was limiting the travel, it was not, I am still a good 1-1/2" from hitting the bump stops on the spindle now, but it just wont turn that far, something else is stoping it.. Dam'd if i can figure out what???
Old Nov 25, 2008 | 12:57 PM
  #44
ggirten's Avatar
ggirten
The backside of your tire isn't hitting anything is it? The only thing I can think of right now would be the gearbox itself.
Old Nov 25, 2008 | 01:29 PM
  #45
Geoff240ti's Avatar
Geoff240ti
Ok.. I snapped some pictures. I'm going to post them in my message, hopefully this is allowed on this forum. If not, I apologize in advance!
My new (to me) F350 I want to modify..
The bumpstop.. you can even see where it hits
The (blown) stabalizer
The bump stop.. pretty much touching
Showing clearance on the spring
The other tight spot..
The 2008
The setup
No stabalizer in sight
Looks like the same u-joints to me...
Miles of space!
I hope these help..
Here is the rest of my gallery for all the pictures I took.
http://www.pbase.com/g_photos/steering
