ChaseTruck754 has shown three pics.
The 1st one is a two drive truck (79) showing the rarely seen 2nd VIN location under tha cab. The main location is just foward of that on the same rail. This can be ideentified with the cab on. The special and rarely seen location requires the removal of the cab.
The other pics are of the same HB (75) frame. This is the actual location on the actual frame. The two different frames had these stamped numbers in the same locations.
