1st off you should figure out if the truck came FACTORY with them or where they PO added. is the truck a Camper Special, does the build sheet show duel batteries?
I have same year f250 and there is a wire that runs across the front that connects the two batteries. Not sure if stock though. I havent messed around much with mine. Not until the weather clears up a bot amd i can get some room on my garage.
If it's factory, it's basically an isolated system to power your camper without running you starting battery dead, and will then charge back up when the vehicle is running. Not really necessary unless you have a mounted camper, but can be handy for certain scenarios. They can be wired to the "hot" pin of your trailer plug, so it piggybacks with a camp-trailer battery. Most of 'em I've seen are either unhooked or re-wired parallel with the starting battery.
I managed to figure out that they are factory, and yes is is a camper special. Truck even comes with a sunroof
I wish I had seen this. I have the same truck sunroof and all. I just ripped out the whole wiring harness or I could have taken pictures of how it was all hooked up with the two batteries.
I'm looking at the 77 wiring chart and it does not show duel battery setup on it. NVM I found it .
Could I take the duel battery setup from a 90s diesel and put it in my dents? Any "special" piece that I HAVE to be sure to grab to make the swap easier? TIA
