Sponsored by: Real Truck
Front Diff - over filled?
Old Nov 12, 2012 | 07:47 AM
mwrohde's Avatar
mwrohde
All -
I changed transfer case fluid and front diff fluid over the weekend. Transfer case was a piece of cake, except for the stupid side-firing drain plug. What a mess.
The diff has me a little concerned, though. I followed Guzzle's advice here: Welcome to guzzle's Front Differential Maintenance Web Page .
That says 5.7 pints for a Dana 60, fill to bottom of threads. I believe my truck has a Dana 50 (2002 F-250, 4.10 gears, 5.4). The owners manual says something like 3.8 pints. It took over 3 quarts (6 pints) to fill to the bottom of the threads. Is that diff now over filled, or is bottom of threads the real test of "full" and I should quit worrying?
Thanks,
Matt
Old Nov 12, 2012 | 08:18 AM
Kdr358's Avatar
Kdr358
Once it comes out of the threads it's full
Old Nov 12, 2012 | 08:28 AM
SC_Hoaty's Avatar
SC_Hoaty
You may want to check the owner's guide again.
I'm seeing for 2002 F250 that you have a Dana 60, 5.7 pint capacity.
(Page 234)
I'm looking at the manual here - http://www.motorcraftservice.com/pub.../02f23og5e.pdf
Old Nov 12, 2012 | 08:42 AM
mwrohde's Avatar
mwrohde
It seems I don't have permissions to that site. But in my book I'm looking at page 273 or 274. I'll check again at lunch.
Old Nov 12, 2012 | 08:45 AM
mwrohde's Avatar
mwrohde
Hmm. I googled for an owner's manual and get directed to the same site you linked. That way I can read it. It's different than the manual in the truck. Maybe it is a Dana 60.
Old Nov 12, 2012 | 08:50 AM
SC_Hoaty's Avatar
SC_Hoaty
I can email the pdf to you if you want. PM me your email address.
I see you are in Sugar Hill. I'm curious about JW Truck Sales there. Won't take this thread off topic, however.
Old Nov 12, 2012 | 08:53 AM
SC_Hoaty's Avatar
SC_Hoaty
There is also a way to recreate your window sticker from you VIN. That may help if you have any questions about what particular items are on your truck.
Old Nov 12, 2012 | 10:02 AM
Buck268's Avatar
Buck268
Originally Posted by mwrohde
All -
Thanks,
Matt
I'm finding the exact some issue on my '99 F250SD with the 5.4L. Owners manual specifies this is a Dana 50 requiring 3.8pts (1.9quarts) of 75w90. Well I just put in two full quarts and its still significantly below the fill hole. No big deal I'll just have to throw another quart in when I get the chance but still a little annoying.
Anyways, I'm about to double check my tag and stamping numbers to see if it may be a Dana 60 instead, as that would make a lot of sense out of the extra capacity.
Old Nov 12, 2012 | 10:27 AM
SuperDutyScaler's Avatar
SuperDutyScaler
you cant overflow it, once it comes out of the fill plug its done. And even if you overfilled it a little it wouldnt hurt. but again once it comes out the fill hole ur done
Old Nov 12, 2012 | 12:04 PM
EXv10's Avatar
EXv10
Fill it to da hole.
Old Nov 12, 2012 | 01:33 PM
Fordfanatic4life's Avatar
Fordfanatic4life
as stated above, you cant really overfill it..
once it leaks outa the drain hole its full..
Old Nov 12, 2012 | 09:56 PM
99f350sd's Avatar
99f350sd
2002 dana 60 SRW
1999 dana 50 SRW
The change happened at the end of 2001.
Dick
Old Nov 12, 2012 | 11:01 PM
pro3qtr's Avatar
pro3qtr
It was said........
countryshiz87
Jan 31, 2012 11:57 PM
oreocreaming
29
Jul 2, 2010 04:12 PM
bigb9582
Oct 23, 2009 04:31 PM
cjcocn
Apr 4, 2009 05:52 PM
fordjeep
Jul 10, 2005 01:17 AM
