Divorced case install
Old Nov 19, 2008 | 03:53 PM
bashby's Avatar
bashby
I was thinking of putting a divorced transfer case behind my 2wd c6 so I can use the low range in tight areas, or sometimes while plowing snow. From what researc I've done I would need to try to get the transmission output shaft parralell to the input on the transfer case, with a 2-4 deg driveshaft angle. I dont have any experience with how the case is mounted to the frame. It seems if there is just a crossmember there might be a problem keeping the 2-4 deg angle, like maybe a brace from the case to the transmission crossmember would be needed. Any pics of divorced cases youve got would help, or links to articles...
badass68hiboy
Offroad & 4x4
Oct 9, 2021 01:26 PM
Ripcity
Sep 27, 2019 11:07 PM
TA455HO
Mar 18, 2013 10:10 AM
714x4
Jul 27, 2010 03:09 PM
Junkyardslug
Offroad & 4x4
Sep 5, 2000 01:06 PM
