carb for 351M?
Old Dec 4, 2008 | 11:37 PM
masterbeavis's Avatar
masterbeavis
Oil pressure sounds normal. I would fiddle with the carb while the motor is warm. If you get it running correctly then it should be OK when cold. If you have ever passed anybody's house with tons of project cars in the yard, stop there 1 day when the garage door is open, and they are out there drinking beer. You might get some good advice on how to tune your carburetor. I still do not know how to do a proper tune on an edelbrock, but with all carbs, I use a vacuum gauge and tune for best vacuum, idle manners, and off idle throttle response.
Once the truck is warm, use carburetor cleaner, or unlit propane to go hunting for vacuum leaks. Do a search on more info on how to do that. Vacuum leaks will make any motor run poorly.
Canus
Dec 7, 2014 09:39 AM
whisler
30
Mar 20, 2011 10:03 AM
77FordTruckMan
13
Nov 6, 2008 12:16 PM
old75F-100
Supercharger, Turbocharger, Nitrous Oxide & Water/Methanol Injection
15
Feb 2, 2006 08:01 PM
mikew
Jul 10, 2003 02:15 PM
