its your ebpv (exhaust back pressur valve) it will do it until the engine warms. it's kinda like that engines coat. keeps heat and pressure in until warm. will do it when it is cold but you can unplug it. tjbeggs or c00nhunterjow may have pics of the plug in their galleries. the plug it on the drivers side of the turbo towards the bottom. it has two wires going into it. just unplug and forget it
X2, your okay. Just the EBPV. You can unplug it, or let it do what it does. Either way you will be just fine. But I wouldn't pull out in front of traffic with it closed. LOL
no sir. just gonna take a tad longer to warm up. i put mine on a switch so i could use it as an exhaust brake but thats all the use it gets now. ive had mine unplugged for a year now and like not having the sluggish power and hissing at first run. no more smoke will be seen either
X2 on the traffic. i did it once with it closed ended up almost in a ditch. figured 4 wheel to get outta a hole or get slammed. there is no power at all when she is closed up
No it won't hurt anything and should cause any smoke.
I've only heard of one downside to unplugging this connector. During the colder months, the engine will take longer to warm up and MAY cause a drop in MPG. There won't be any affect during the warmer months. This is according to my Ford mechanic.
I had my EBPV unplugged last year and mileage did go down a bit (about 1.5 MPG) during the colder weather. It also set a code that my buddies Edge Evolution did not see but the dealership's $5000 scanner did see. Don't remember what the code was.
I have the EBPV plugged in for now. It hasn't been that cold yet. My warm weather months MPG is around 18 and my current MPG with the weather cooling off is around 16.5 - 17. The defroster and heater seem to work better with the EBPV plugged in, but that's IMHO.
I am on 78 right now headed your way...I am at the Pa. line.......not sure how far I am from you...but I would be glad to show you where its at...9893120138....I will be driving so give me a call or I can talk you through it.
haha you guys are awesome thanks alot. id call you but its time id get some sleep.
should i make it so i can switch it on or off?
also another random question. truck winds up then bangs in gear every now and thenbut the trans is there its solid is it an electrical issue...speed sensor?????
andddd
what do i do if i can only get my truck into 4wd high the lever wont move past it i cant get 4wd low
Sounds like it's in limp mode. You may want to run the codes.
andddd
