help before work tomorrow please
Old Nov 19, 2008 | 12:21 AM
immastrokinnow's Avatar
immastrokinnow
reps sent ron...
Old Nov 19, 2008 | 01:06 AM
ron86toy's Avatar
ron86toy
Originally Posted by RubberDuck
Atta boy Ron. Tried to rep.......
Originally Posted by immastrokinnow
reps sent ron...
Thanks guys.......sure I will work on a truck after a 1100 mile day...LOL
I'll play on here for a bit...then I need some sleep.
Old Nov 19, 2008 | 06:36 AM
scbronco's Avatar
scbronco
what do you mean push it down?
im lost
Old Nov 19, 2008 | 08:42 AM
ron86toy's Avatar
ron86toy
im lost
when in 4h..push lever strait down and move to 4L at same time
Old Nov 19, 2008 | 04:33 PM
scbronco's Avatar
scbronco
i guess i dont have the technique when i press it straight down it pops back into 2wd
Old Nov 19, 2008 | 04:44 PM
NWBronco's Avatar
NWBronco
Pull back into 4Hi, keep pulling back, and push it down, and it will drop back into 4Lo. It is a spring loaded detent that you have to get the lever down into. Once you do it, you'll have it down.
Old Nov 19, 2008 | 05:30 PM
secondarychaos's Avatar
secondarychaos
Ya, it can be difficult, but you get used to it.
Old Nov 19, 2008 | 08:20 PM
scbronco's Avatar
scbronco
are these common to malfunction....cauase it aint working sorry to make such a fuss about a stupid little thing
Old Nov 19, 2008 | 08:36 PM
NWBronco's Avatar
NWBronco
Not as a rule. They can gum up though. There is a rubber boot that covers it. If it fills with crud it will made it hard to shift.
Old Nov 19, 2008 | 08:51 PM
scbronco's Avatar
scbronco
i get nothing i put it up and it stops in 4 hi thats it i push down it goes back into 2wd
Old Nov 19, 2008 | 09:28 PM
JethroF250's Avatar
JethroF250
pull back on the lever and at the same time push down on it keep pullin back and there is 4lo
Old Nov 19, 2008 | 09:42 PM
ron86toy's Avatar
ron86toy
did you get your EBPV disconnected?I went through on 80 about 3 hrs ago.....forgot to check on here
Old Nov 20, 2008 | 06:50 AM
  #28
scbronco's Avatar
scbronco
nopeeee
Old Nov 20, 2008 | 08:44 AM
  #29
JethroF250's Avatar
JethroF250
i think i have a pic that may work
Old Nov 20, 2008 | 08:47 AM
  #30
JethroF250's Avatar
JethroF250
sorry i didnt have a better pic but i hope this helps you. the red wire is for my switch going to the EBPV. just follow how it loops down towards the bottom of the turbo and you should have an idea of where the plug is at. it has two wires going into it. and is plugged into the side of the turbo
