Primary rig is Green Thunder:
95' F-150 XLT 4x4, 302, 5 spd, MSD 6A, Sunroof, CD player with 2 10" subs and some 32" BFG Muds .
Check out my Gallery for a look-see.
Then theres:
99' Mustang GT 4.6L
88' F-250 Superduty 4x4 351/c6
95' Mercury Cougar 4.6L V-8
80' E-350 300/6 with a
3 spd column shifter. Top speed is 65mph, Go Baby Go!
Actually yes. Check out all of those rock climbers. Super cushy springs and 35s, 37s, and larger. You might want to look at some of the older box Bronco aftermarket suppliers. Also, if you know the rate of your current springs, a good spring manufacturer can build a spring with lift and a softer rate. You probably are going to find a 2 stage spring more to your liking though.
