Radio Problem / issue
Old Nov 18, 2008 | 06:04 PM
afonda's Avatar
afonda
Ok here is scenario...
Put key in ignition... turn forward but dont crank engine... radio comes on... turn key forward and crank engine... truck starts... radio goes off during cranking and does not come back on for about 30 to 60 seconds after truck starts ...
wierd... or is this normal...????
Old Nov 18, 2008 | 06:09 PM
superduty4x4's Avatar
superduty4x4
Wierd. Have you checked the plug on the back to see if it's connected tight and everything is clean? It could be that your batts are getting weak and don't have the juice to run the radio until the alt. charges it up some.
Old Nov 18, 2008 | 06:18 PM
afonda's Avatar
afonda
engine cranks hard and strong (spins fast).... doesnt seem like the bats are low. I can check them though.
What voltage should the bats be showing?
do you measure them individual or are they run in series????
Old Nov 18, 2008 | 06:45 PM
Izzy351's Avatar
Izzy351
They are in parallel. You check the voltage across one, you're seeing both. BUT... Sometimes just one can get weak, and the other will mask the problem. That also happens if someone replaces only one battery instead of both (like should happen!). Might be good to check them individually by pulling the pos cable off. How old are they and what year is your truck?
Old Nov 18, 2008 | 07:12 PM
empiretc's Avatar
empiretc
what kind of radio? Factory single disc or 6 disc?
Old Nov 18, 2008 | 07:50 PM
afonda's Avatar
afonda
model yr.. 2002
not sure on age of bats.
6 disc ford factory radio.
Old Nov 18, 2008 | 08:34 PM
empiretc's Avatar
empiretc
ok, then run a self test on it and let us know if it spits out a code. here is how:
1. Turn the radio on and place it in AM/FM mode
2. Simultaneously press the audio unit preset buttons 3 and 6 to enter speaker walk around test mode.
3. Press Preset button 1 to start the self test
4. After the self test is done use the “DISC TUNE” right button to display the codes
5. To exit the self-diagnostic mode, turn the ignition switch off or the audio unit off.
Old Nov 19, 2008 | 04:30 PM
empiretc's Avatar
empiretc
anything....????
Old Nov 19, 2008 | 04:33 PM
nlindelldc's Avatar
nlindelldc
I certainly don't mean to hijack this thread, but my 6 disc CD changer keeps saying "bad disc" and won't read any of them. Is there any point to me doing this test?
Old Nov 19, 2008 | 04:36 PM
empiretc's Avatar
empiretc
yes- it will show you an error code to help you diagnose the problem.
Old Nov 19, 2008 | 04:48 PM
nlindelldc's Avatar
nlindelldc
so if I give you an error code can you tell what the problem is? And if so, what are the odds that I could fix it myself and not have to send it somewhere? (last question, I promise.....again, not hijacking thread...ha)
Old Nov 19, 2008 | 06:40 PM
empiretc's Avatar
empiretc
this list of codes can be found here:
Troublcodes.net Trouble Codes OBD & OBD2 Trouble Codes and Technical info & Tool Store. By BAT Auto Technical
Old Nov 20, 2008 | 03:17 PM
afonda's Avatar
afonda
I will check the radio 2nite.
dont worry about hijacking the thread cuz I actually have the same CD problem w/my radio. It won't eject or load and says CD ERROR.
I will update once I run the prescribed test.
Old Nov 20, 2008 | 03:53 PM
empiretc's Avatar
empiretc
cool, we'll see what's up.
Old Nov 20, 2008 | 05:41 PM
afonda's Avatar
afonda
Ok... ran the precribed test... and.....
Codes:
U2005 RICP
U2008 Phone
U2003 CDDJ
