U2005 - Audio Rear Integrated Control Panel Unit is Not Responding
U2008 - Audio Phone is Not Responding
U2003 - Audio Compact Disk / Disk Jockey Unit is Not Responding
I am guessing you have none of the options installed. I do not and I receive all these codes as well. I am guessing your problem is probably a loose or chaffed wire.
Empiretc....
Not sure what options are installed for the radio. I just bought this truck and I am learning about it. what I do know is the radio works good but the cd player is not working.
I loaded one cd in the cd player slot #2 and then it crapped out on me. It says there are no cd's in the cd player even though I loaded one and it is still in the radio / cd player. I am concerned that I cannot get my cd back out.
I can confirm the power problem started after the cd error problem.
I had a power problem with my 02 radio. Ended up that the plunger in the drivers door knock the wire bundle loose and cut through the insulation on a wire. It was very easy to pull the door cover and tape wire. Just a thought.
