Modular V10 (6.8l)
Cat confusion
Old Nov 18, 2008 | 11:21 AM
semcderm's Avatar
semcderm
Cat confusion
My 2000 has a cloggged cat, what are the options out there ? Magnaflow recs 99509HM becuase of the engine size and test weight of vehicle but list is $ 394. They said a smaller cat would burn up. What is everyone out there running and has anybody burned one up ? I know DKF and Skipperw run smaller ones and MF has lots of ones rated for 6.2l and 6000 lbs. I would like to run the smallest quietest and cheapest one out there in front of a 5 x 11 x 22 #14578 MF muffler, Thanks
Old Nov 18, 2008 | 11:28 AM
dkf's Avatar
dkf
I have a Dynatech cat on my truck. Well over 15k miles and I havn't burned it up yet. Nice thing about the Dynatech cat is if you burn it up its easy to gut and put a pipe through.
Old Nov 18, 2008 | 12:06 PM
semcderm's Avatar
semcderm
how much louder was that little cat DKF ?
Old Nov 18, 2008 | 12:36 PM
dkf's Avatar
dkf
I can't really say. I put on a louder muffler and new piping at the same time as the cat. If you let the exhaust exit in the stock location I think you'll hardly notice a difference in sound between the stock cat and smaller cat.
Old Nov 19, 2008 | 01:39 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
If you're going to be towing a lot, or hauling heavy, I would go with the larger one so it doesn't get overstressed.
If it's a daily driver, and you just want to fix it right away cheap, and you're not going to be pulling heavy loads, I wouldn't worry about it too much.
Old Nov 23, 2008 | 03:37 PM
semcderm's Avatar
semcderm
I bought the MF 95509 cat it was rated for 7.5 liters and 13000 gvw and reccomended for the 6.8 liter and under $ 100. magnaflow reccomended their new 99509 Heavy Metal but it was like 50 bucks more, both have the same 4 tall x 7 wide by 15.5 body. I did not know the difference but figured it was probably just a new type of catlyst. Anybody have a clue what "heavy metal" woould refer to?
Old Nov 23, 2008 | 04:55 PM
Skoda's Avatar
Skoda
I'd put my fingure on a thicker gauge metal I.E more resistant to rust, metal fatigue.
Old Nov 23, 2008 | 07:34 PM
meanv10's Avatar
meanv10
Cut it off and "clean it out" then reinstall.
Cheap and free.
Old Nov 24, 2008 | 10:42 AM
krewat's Avatar
krewat
Cheap and free.
And against Federal Law. Also not cheap when you fail emissions inspections, depending on the state your living in
LRShooting
Dec 5, 2014 12:00 PM
V10man
Modular V10 (6.8l)
Nov 3, 2014 04:45 PM
PJPVI
Jan 13, 2014 06:44 AM
sdetweil
41
Mar 5, 2010 07:53 PM
f100guy
Jul 20, 2004 07:23 PM
