clogged cat
Old Jul 19, 2004 | 09:38 AM
f100guy's Avatar
f100guy
clogged cat
hello my wifes dad has a 93 e250 with a 351. if you hold the gas to the ground it will cut out bad and start backfiring. i walked in front of the exhaust pipe and the gases burned my leg hairs. then i looked at the cat and the whole pipe and part of the cat were glowing red. i was pretty sure that that was bad. so the bad cat would be the one that is after the glowing pipe right.
Old Jul 19, 2004 | 09:55 AM
quicklook2's Avatar
quicklook2
yes.
disconnect exhaust in front of suspected bad cat, with pipe cool of course, then see how it runs.
if more than one replace them all.
Old Jul 19, 2004 | 10:01 AM
f100guy's Avatar
f100guy
i believe it has one where the 2 pipes come together and then the big one after that. but they don't unbolt at the cats. only at the manifolds. he is only going to take the pipe after the cats down and then punch out the second one since money around here is limited. he will be getting a replacement soon.
Old Jul 19, 2004 | 08:09 PM
Egor's Avatar
Egor
Pull the codes and see if it is running too rich. It sounds like you're pouring too much fuel too it, causing it to burn in the cat.
Old Jul 20, 2004 | 07:23 PM
f100guy's Avatar
f100guy
no we found it out and it is the other way around. it is not getting enough fuel so it is lean. we got the cat replaced and it still does it, but it does sound better. we tested the fuel and it stays over 40 psi at idle but when revved it drops far below 30. so the fuel pump is bad and we have been looking for one for the past 12 hours
blue924.9
Oct 14, 2015 05:04 PM
dylanellis
39
Sep 28, 2011 08:10 PM
FX4 5.4
Exhaust Systems
Oct 8, 2009 10:38 AM
Andy Young
1997 - 2003 F150
13
Nov 15, 2006 03:22 PM
