Choke not pulling off
Old Nov 17, 2008 | 10:40 PM
alconk's Avatar
alconk
I removed the reman. carb that was on my 302 and replaced it with a rebuilt carb. off my 77 T-Bird that had a 400 and runs great but the choke is staying on forever and can't seem to get it to come off.... The choke is part electric part manifold heated meaning there is a tube that comes from the exhaust manifold to the choke housing. There is also a 12 volt source that plugs into the choke so I really not for sure what the problem could be?? Any thoughts? I don't know where to even adjust it??
Old Nov 17, 2008 | 10:44 PM
pfogle's Avatar
pfogle
Is the engine ever getting to operating temp? I mean above the N on gauge? Are both the choke stove and the electric hooked up?
Old Nov 17, 2008 | 10:45 PM
alconk's Avatar
alconk
Yes it gets up to operating temp actually above it and both the choke stove and the electric is hooked up???
Old Nov 17, 2008 | 10:48 PM
pfogle's Avatar
pfogle
Test the wire going to the choke. Make sure it's got 12v. From there is the choke moving? What carb is it, and how is the choke set up? The carb on the 460 in my '77 is a bear, the choke pull-off is internal and all the linkages stick. It's a beast to start when cold if you forget to set the choke before you get in it. Is there a vacuum pull off that's not operating correctly?
Old Nov 17, 2008 | 10:52 PM
alconk's Avatar
alconk
The choke will come off I just have to keep tapping the throttle until it does. Haven't checked for 12V yet but I will. It has a external choke pulloff and I believe the carb is a 2150?? Sound right?
Old Nov 17, 2008 | 10:59 PM
pfogle's Avatar
pfogle
2150 2bbl. Yup, check and make sure the choke housing where the choke stove attaches isn't broken. I had one a '79 LTD break and then the choke didn't pull off ever. If that checks out then you might want to adjust the choke pull off. On the back side of the vacuum pull off there is a round access hole. There is a 1/4 bolt there that you use to adjust the pull off. It should pull off just enough the let the engine run until the electric/choke stove has heated up enough to pull it off the rest of the way.
Old Nov 17, 2008 | 11:05 PM
alconk's Avatar
alconk
Oh interesting I wondered why there were both... Well when you first start it cold it runs on fast idle then you tap the accelerator and the fast idle comes off. But the wierd part is while waiting for the choke to completely come off it goes back into fast idle then it takes forever for that to come off but it will eventually. Does that make any sense??
Old Nov 17, 2008 | 11:06 PM
alconk's Avatar
alconk
Oh my choke stove tube isn't broken either.
Old Nov 17, 2008 | 11:24 PM
pfogle's Avatar
pfogle
Yes, that's normal. Until the choke pulls off it should run on fast idle. It sounds like the vacuum pull-off is not working to me. You need to have a helper start the car while you have the air cleaner assembly off. Watch the choke plates, if they move after the truck starts then the pull-off is working and needs adjusted. If they don't move at all the pull-off is not working, make sure there is vacuum to the line on it, and from there replace if needed.
Old Nov 17, 2008 | 11:37 PM
fmc400's Avatar
fmc400
MSEE
If you use your DC meter to check the choke voltage, you're only going to see 6-7 V RMS. This is because the stator signal is actually AC, so don't be alarmed if you don't see 12V DC. Take a look inside your choke cap and make sure the spring is intact. It grounds by the tang slipping into the choke linkage itself. Here's my writeup on pretty much everything you need to know about setting up the choke and fast idle on a 2-barrel carburetor. There is a part about indexing the choke cap properly. Ignore the first couple paragraphs about the float.
https://www.ford-trucks.com/forums/7...ml#post6422219
Old Nov 18, 2008 | 01:02 AM
alconk's Avatar
alconk
Very good article, I'm kinda with you kinda not. I will print this off and take it out there with me. But here's a funny thing, I checked the choke housing and it's fairly new but the wire going to the choke will read about 6-7 RMS like you say but when you attached it to the choke and then check it it reads 0. That confuses me
Old Nov 18, 2008 | 01:49 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
DOAZ9J549C .. Choke Pull Off Diaphram (Motorcraft CK1283).
This diaphram doesn't usually come with carb kits, must be bought by itself.
Fits: 1970/79 Ford 2V carbs except 1977/79 VV's.
Mounts under a cover on the airhorn that uses three screws to retain it.
All you see is the diaphram's 90 degree rod poking out of the cover.
Careful when removing the diaphram, there's a coil spring beneath it.
Old Nov 18, 2008 | 01:56 AM
alconk's Avatar
alconk
DOAZ9J549C .. Choke Pull Off Diaphragm (Motorcraft CK1283).
NumberDummy, you are one awesome guy!!
Old Nov 18, 2008 | 02:25 AM
fmc400's Avatar
fmc400
MSEE
You should check the voltage when it first starts, and then check it again after it runs for a few minutes to see if it changes. The reason for this is because the electric heating element in the choke is a positive temperature coefficient (PTC) heating element - meaning that it presents a very low resistance and draws a lot of current at first which will make the voltage read very close to zero. As the element heats up, its resistance increases until it approaches open-circuit, at which point the voltage will return to 6-7 V RMS. If the choke power reads 6-7 V RMS when disconnected (normal) but stays at zero after you connect it and leave it running for a few minutes, then it's possible that your choke cap is bad. In that case it might be shorting to ground.
The stuff to pay attention to in the article is the choke cap index part because it shows you how to adjust how long it takes the choke to open up. If you're not having any problems with the idle kicking down then you can probably skip over the fast idle stuff, but if your choke never opens then I'd imagine your idle never kicks down, so you won't know if that's good until you get your choke to open.
Old Nov 18, 2008 | 03:54 AM
NumberDummy
The plastic fast idle cam is notorious for snapping in two.
D5AZ9597A .. Fast Idle Cam (Motorcraft (CM2105A)
