engine swap ?
Old Nov 17, 2008 | 01:36 PM
sanfortandson's Avatar
sanfortandson
engine swap ?
A buddy of mine has a 1986 f-150 302 fuel injected that is basically wore out. I had a 1989 351w carb motor out of ford ltd squad I sold him. ? what would it take to make the 351w carb motor work in place of the 302 fuel injected motor. can we bypass some of the wiring, change fuel pump or just P------s in the wind try something different. All question and answera welcomed.
Old Nov 17, 2008 | 03:48 PM
Conanski's Avatar
Conanski
On this truck that swap isn't too much trouble. What you need to do is get the duraspark ignition system to go with the 351, and bypass the frame mounted high pressure fuel pump, the tank/s have low pressure pumps inside. The motor will bolt right in but make sure you have the right flywheel/flexplate for he 351, it's 28oz balance and the 302 is 50oz. Last thing to deal with is the exhaust, the factory Y-pipe will have to be modified as the 351 is wider, not a big deal and if you have duals no problem at all.
Old Nov 17, 2008 | 04:41 PM
pfogle's Avatar
pfogle
IF he still has the entire LTD a LOT of the exhaust parts should work fine. You may have to do some tweaking here and there.
Old Nov 18, 2008 | 09:39 AM
sanfortandson
swap
I will forward this info to him Thanks, And if we have problems I'll let you all know. thats for sure.
coldsteel187
Sep 8, 2010 11:48 PM
Krazy351w
Engine Swaps
Sep 15, 2008 05:04 PM
joewaldner
Electrical Systems/Wiring
Jul 18, 2007 10:05 PM
joewaldner
34
Jul 17, 2007 02:13 PM
HotWhlz85
Feb 26, 2002 11:04 AM
