electronic fuel injection
Old Jul 3, 2007 | 02:01 AM
joewaldner's Avatar
joewaldner
how does stock 1990 fuel injection for a 351w work... to each piston seperatly? or front half back half ?
and will it work with a 302 motor?
Old Jul 3, 2007 | 12:04 PM
Franklin2's Avatar
Franklin2
I believe the trucks were batch fire, divided into left bank and right bank. A 351w fuel injected system will be calibrated for the larger 351w. A 302 will probably run, but not very well.
Old Jul 18, 2007 | 01:56 PM
joewaldner's Avatar
joewaldner
how hard is it to change the computer if it does run badly
Old Jul 18, 2007 | 10:05 PM
Franklin2's Avatar
Franklin2
Check the injectors to see if they are a different color. I am not sure, but the 351w might have had larger injectors, which will throw everything off a little bit. You could also go to www.partsamerica.com and pretend to order injectors for each vehicle and see if they are the same part number.
pinkhorse
Jul 1, 2004 08:56 AM
bpatton74
Mar 6, 2004 11:21 PM
berniek
Oct 3, 2003 12:20 PM
mike460
Jul 5, 2001 10:31 PM
