Well I finally got a new job and im ready for more motor mods. True duals with X pipe and flowmaster 44s are going to be put on next week and after that im ready for more. Pretty much all I have is LT headers,plugs,wires,dist cap. Im wanting to dump all my money into the motor and want to know the best way to go. I was thinking I would build the current motor to a 331 or 347. But I was wondering if it would be easier to drop a 351 in it and have even more cubic inches. Or maybe even just building up the 302 without boring/stroking it?
Another thing im wondering about is if I should stay EFI or go with a carb for any of these setups. Maybe a MAF swap to start off with?
I have another truck I can drive any time I need to so my truck can sit while all this work is being done.
I 2nd that. Put a 351w in there. Cross your fingers that the exhaust will bolt back up though. I would say it should, but if your duals for the 302 come close to the frame on the outside of the pipes, then it may not work. When you put the 351w in there, it is wider than the 302.
Go with the 351w, the pipes should be really close to fitting. You will probably need to redo a little bit of the pipes anyway cuz you really need to put headers on that 351w, cuz it will really wake that motor up
MAF swap isn't necessary unless you make a large change to the amount of vacuum for the MAP sensor, for example using a fairly large cam will do that.
if it was me, I would go with a 351w, AFR 185 or 205 heads, edelbrock victor jr. EFI intake manifold, 24lb injectors, lightning/gt40 351w lower intake manifold with a gt40/explorer/cobra upper intake manifold, 70mm throttle body, and keep the stock cam and SD EFI.
It will make about 310rwhp/360rwtq, and rev to about 5500 with good power. Later on, a MAF swap with an 80mm MAF sensor housing and a larger cam like an anderson motorsports N-41 with a roller conversion would be a great bolt on.
Except that won't work... the SD computer is calibrated for 19lb injectors so the HP level they support(about 300hp) is as far as you can go. A motor that breathes well enough to require bigger injectors means it also needs programming and/or a MAF upgrade depending upon the cam specs.
I ran 30lb injectors with no tune on my old `87 coupe with a trickflow tw head/anderson ford n-41 cam/typhoon intake combo with nitrous and I saw no issues with drivability, and it made 317rwhp, or about 370hp at the crank n/a, I did run the o2 sensors disconnected (to keep the ECU in open loop) and used an adjustable fuel pressure regulator and a wideband a/f monitor (LM-1) to set the fuel pressure. IIRC I was running 35# fuel pressure at idle vacuum off and capped, it showed 38 or 39# at idle with the vacuum on the regulator.
Ok I think what Im going to do is buy a used 351w for cheap and slowly build it up then when I go to put it in my truck Ill have my AOD built to handle it.
I ran 30lb injectors with no tune on my old `87 coupe with a trickflow tw head/anderson ford n-41 cam... I did run the o2 sensors disconnected (to keep the ECU in open loop) and used an adjustable fuel pressure regulator and a wideband a/f monitor (LM-1) to set the fuel pressure.
This just demonstrates that your definition of "no problem" is a lot different than somebody else's. There's not a chance in hell this thing idled like a stock EFI motor or could pass emissions.
Assuming an SD 5.8 computer it'll work as well as similar mods to the 5.0, that includes cams that actually open the valves, head porting and exhaust work, that will stretch the 19lb injectors for all they're worth and generate close to 300hp. And you can have stock like idle and drivability as long as the cam is SD EFI friendly, that means less than 215 deg duration at 50 thou, and at least 114 deg LSA.
it idled and ran fine, I daily drove that car through a couple of years of college until some retards stole it and wrapped it around a curb 2 blocks from my house.
The guts of it are in my `89 4cyl coupe now, and it doesn't really run all that different with MAF, the MAF setup needed a tune just as much as the SD setup did, it was just nice to have tweecer forums to get a baseline for the MAF that I'm running to get it close.
