Eaton True trac ?
Old Jan 24, 2009 | 10:12 AM
clevelandjim's Avatar
clevelandjim
Does the True Trac repalce the R&P gears also - 2 birds with 1 stone?
Old Jan 24, 2009 | 11:29 AM
Ranger1F150's Avatar
Ranger1F150
no, well you could at the same time.
the ring gears mounts to the diff weather it be an eaton true trac or a stocker or other brand.
while you are installing a new diff you might as well put new gear set in if you were planning to change your gear ratio, or if you are changing your R&P you might as well upgrade to a better diff if you have an open diff or a worn out stock limited slip.
I am keeping my stock R&P and just changing out my diff
eberlestock
Apr 20, 2017 06:53 PM
brada
Jan 8, 2017 11:51 AM
freesoul
Jun 29, 2016 10:57 AM
Buck268
May 9, 2016 02:56 PM
mueckster
35
Nov 17, 2009 09:57 AM
