Sponsored by: Innova
FM Transmitter
Old Nov 16, 2008 | 05:35 PM
boxcar1974's Avatar
boxcar1974
FM Transmitter
I am still in the stone age and I burn CD to play in my truck. I have a HiFi sound system and don't have the ability to play mp3's. I was looking at FM transmitter that links the mp3 player and plays through your speakers.
Are these any good? How is the sound quality? I have a HiFi system so the quality is VERY important. Any potential problems?
Thanks
Old Nov 17, 2008 | 12:01 AM
ReAX's Avatar
ReAX
Please define High Fidelity. The music put on to CD is sampled at 44.1k times per second. Then if your making MP3s out off the CD, your loosing about half of the samples for compression. MP3 is not high fidelity, it's more of compromise to storage space, but the average listener can't tell the difference. However, these sampling rates and compression are why Vinyl is still considered to be the best in some circles.
Human hearing is expected to be in the 20Hz to 20,000Hz range. FM radio only transmits 50Hz to 15kHz. I would only expect the FM receivers/transmitters to reproduce that range so your going to loose 30Hz on the low end and 5kHz on the high. Can hear below 50Hz or above 15kHz? If not then using a FM modulator will work fine, if your going to want those freqs then no, don't use them.
Tell us a bit more about your stereo system, there are probably other options. If it's a stock hifi or premium system, then disregard everything else, they aren't as faithful as I was going.
Old Nov 17, 2008 | 10:20 AM
7283-F250's Avatar
7283-F250
In reguards to FM transmitters and iPod/MP3 players.
I have one I use in my old cars with no Aux port on the radio. I lucked out and it seems to work well with my iPod. Some FM transmitters are better than others.
Mine is an iTrip and designed to only plug into my iPod. I can choose any station from 87 to 108. I do have to change the output station from time to time as I come across radio transmission on the chanel I am using. The radio output will overpower my FM transmitter.
I highly recomend looking into some kind of direct hookup and if you have to get a FM transmitter get the one with the 200 station sellection (87 to 108) and not the 3 chanel selection.
I just got a new Alpine headunit for my 01 car and it has a iPod direct connect and my 07 Ranger has the Aux port for anything that will plug into the 3.5mm jack.
SWD
Escape & Escape Hybrid
Feb 29, 2012 09:47 PM
FarmForward
Jul 10, 2011 08:01 PM
VinnyP
Mar 27, 2011 08:28 PM
BlakeBott
2004 - 2008 F150
Mar 16, 2006 02:17 PM
