Sponsored by: Real Truck
How Embarassing
Old Nov 16, 2008 | 11:41 AM
squigler's Avatar
squigler
How Embarassing
So up to the hunting camp i go with my quad and trailer in tow roll around in the camp yard go to back in and no traction so flip the 4+4 switch and nothing happens no clunk or nothing could have crawlled under a stone.
Where do i start to look for the problem?HELP!!!
Old Nov 16, 2008 | 12:27 PM
zack7.3's Avatar
zack7.3
Does your air conditioner blow to defrost only? If it does you probably need to look for a vacuum leak. That is the default setting when you have a leak.
Old Nov 16, 2008 | 12:54 PM
Richard_cranium's Avatar
Richard_cranium
if you have th ESOF you must roll forward a couple feet. If you can't you must get out and manually lock the hubs
Old Nov 16, 2008 | 01:11 PM
squigler's Avatar
squigler
vacum is fine rolled back and forth for 10mins and the hubs are automatic
Old Nov 16, 2008 | 01:31 PM
06silvercrew's Avatar
06silvercrew
Is the front driveshaft spinning?
Old Nov 16, 2008 | 01:39 PM
artfuldodger's Avatar
artfuldodger
Did you remember to place the truck in neutral and put your foot on the brake before you shifted into 4 wheel drive?
Old Nov 16, 2008 | 01:44 PM
squigler's Avatar
squigler
no i didnt do that i dont have a owners maual but i never did that to my last two trucks (f150-F250) Is this somthing to do with the s/d trucks?
Old Nov 16, 2008 | 01:46 PM
squigler's Avatar
squigler
i never got the clunk noise but the dask lights came on
Old Nov 16, 2008 | 01:47 PM
laka's Avatar
laka
Dont think neutral is necessary for shift on the fly
Old Nov 16, 2008 | 01:48 PM
aldridgec's Avatar
aldridgec
Did you try to manually lock the hubs like were suggested? How do you know you don't have a vacuum problem?
Old Nov 16, 2008 | 01:52 PM
squigler's Avatar
squigler
there not manual hubs and everything works fine as far as the a/c and heater
Old Nov 16, 2008 | 02:17 PM
artfuldodger
Obviously you don' t put it in neutral for 4H since this is designed for "on the fly " shifting but if you shifted into 4L then it won't shift until you are in neutral and foot on the brake. same is req'd to shift out again.
Old Nov 16, 2008 | 02:19 PM
jdecker88's Avatar
jdecker88
You can manually get out and lock the hubs in and then lock the switch in.
Old Nov 16, 2008 | 02:53 PM
squigler's Avatar
squigler
how do i lock the hubs when theres nothing to turn and how do i lock the switch in
Old Nov 16, 2008 | 02:55 PM
jdecker88's Avatar
jdecker88
All 99+ trucks with manual or auto hubs have a locker on the hub that allows you to turn them on auto or lock them in manually.
