Sponsored by: Real Truck
How Embarassing
Old Nov 16, 2008 | 03:15 PM
5.4L to Freedom's Avatar
5.4L to Freedom
Try 4 low, if nothing happens there I would assume t-case solenoid. That should make noise.
Old Nov 17, 2008 | 06:53 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
BIG QUESTION:
Did the 4x4 light in the dash come on?
Old Nov 17, 2008 | 08:33 AM
WildWildWest's Avatar
WildWildWest
What Krewat said and does the 4X4 switch have lights on (meaning when the dash lights are on). This happened to mine and all that was wrong was that the connection behind the switch on the dash was loose. Pushed it in and it worked fine. Start simple and move to bigger problems like T-case motor. Also check connections to the t-case motor. And, as others suggested, move hub selector to manual and try it again. Just keep troubleshooting.
Old Nov 17, 2008 | 09:37 AM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
Originally Posted by squigler
how do i lock the hubs when theres nothing to turn and how do i lock the switch in
Turn the **** in the middle of the hub from "auto" to "lock"
Old Nov 17, 2008 | 01:49 PM
mitchntx's Avatar
mitchntx
Do you hear anything when you press the switch?
On my 93 Bronco I could press the switch to go into 4WH and I would hear some "clicking noises" under the dash each time I would press the button. I believe it was the solenoid's relay energizing and de-energizing. This is normal, BTW.
But I wouldn't hear or feel the transfer case engage.
There is a solenoid on the backside of the transfer case and it engages and disengages the gear set. Mine would "stick" and not engage. It was worse when the weather got cold.
While someone is pressing the 4x4 button, crawl under the truck and lightly tap the drive mechanism of the solenoid with a hammer. Don't whack it hard, it's just cast metal case. But just enough to vibrate or shock the sticking plunger inside.
Once it engages, drive it around a bit to build some heat into the transfer case and cycle the unit 3 or 4 times to loosen it up.
Once that happenes remember to engage 4x4 several times a year in an attempt to keep it loose.
My experience ... HTH
Old Nov 17, 2008 | 02:08 PM
FordxFour's Avatar
FordxFour
Sorry if this is a little off topic, but does the T-case in the ESOF have a physical neutral, that it is just bypassed by the solenoid, meaning that if you converted it over to a lever shift, so you could benefit by having a neutral if you wanted?
Old Nov 17, 2008 | 02:11 PM
brian42's Avatar
brian42
Veteran: Navy
Originally Posted by artfuldodger
Did you remember to place the truck in neutral and put your foot on the brake before you shifted into 4 wheel drive?
That's only go from 4Hi to 4Lo and 4Lo to 4Hi. 2wd to 4Hi and back is only a click of a switch (under 55mph).
You should have a manual lock on the hub (auto/lock positions). Do you have an aftermarket rim that has a solid center piece on it? That could be covering your hub actuator. Pop the center cap off your rim and look at the hub, it should have a lever to rotate. Rotate it clockwise until it stops and you will lock the hub manually. Rotate it counter-clockwise and it will go to "auto" which puts your hubs at the mercy of your dash switch.
I don't know of any hubs for the SD that don't have a switch (OEM or aftermarket). They all have a manual lock.
Old Nov 17, 2008 | 03:48 PM
enduro4231's Avatar
enduro4231
What year did they go to the dash-mounted switch? My 2002 still has the floor 4x4 shifter.
Old Nov 17, 2008 | 04:16 PM
superduty4x4's Avatar
superduty4x4
The manual shift T-case like yours was standard, ESOF was an option. Most will tell you the manual is the better option to have. My early 99 F250SD has ESOF.
Old Nov 17, 2008 | 05:24 PM
enduro4231's Avatar
enduro4231
I see, thanks! I guess K.I.S.S. applies in this case.
BTW- Thumpertalk is another awesome forum! I'm on there under the same name, frequenting the Kawasaki 2-Stroke and General forums.
Old Nov 17, 2008 | 08:05 PM
squigler's Avatar
squigler
yes it did the dash lights work fine
Old Nov 17, 2008 | 10:56 PM
krewat's Avatar
krewat
If the 4x4 light comes on in the instrument cluster, that means the transfer case is actually shifting into 4x4.
Sounds like the hubs aren't locking - try locking them by hand and checking out 4x4.
If it works with the hubs locked, then start diagnosing the vacuum hubs.
Old Nov 18, 2008 | 07:03 AM
  #28
jeffdoerr's Avatar
jeffdoerr
my truck did the same thing, 1 time. NEEDED 4wd, hit the switch and nothing, no light, no clunk. After 10 or 15 minutes, it worked again.
Wonder if there is a corroded wire near the shift motor ? MAybe a dirty plug ?
I am thinking these are set up just like all fords with electric shift ? Dash switch, shift computer and shift motor ? 9 times out of 10 the shift motor has some wear or corrosion inside the gear head on the selector switch, which is normally non-repairable.
Process: Driver select 4h, computer sets go signal to shift motor, shift motor manually rotates modified shift lever on transfercase to 4h pos. If truck is equipped with vac hubs, the solenoid for the vac hubs is engaged and hubs lock onto axel shaft. If manual hubs, driver must manually engage lockouts.
Driver select 4l, computer check to see if truck in N and/or foot on brake pedal. Process continues as if 4h, but selecting 4l.
I think this setup was brought to public use in 86 on the rangers and bronco II. I worked on a lot of these, all my years of this and I only changed 1 shift computer and 1 set of switches, the switches from abuse, the owner punched the switches because the shift motor did not work.
Old Nov 18, 2008 | 07:51 AM
  #29
m350's Avatar
m350
A buddy of mine had an 04' F-350 Harley-Davidson, 4x4,,and you could not see any hubs with what was thought to be the stock wheels on that truck !! I thought this was kinda strange,,,I am assuming that the center caps were infact hidding the Auto/Manual hubs,,,he said his 4x4 worked but I really cant recall seeing another 4x4 SuperDuty with hubs you cant see ! Anybody else ever see one ??,,,,,,,Check your center caps,,may be hidding your hubs.
dlibson
Minnesota Chapter
1290
Dec 2, 2011 08:30 AM
kjg26
Georgia Chapter
Sep 1, 2006 11:48 PM
CBSuperduty
Nebraska Chapter
Mar 20, 2006 03:26 PM
black wolf
Ontario Chapter
May 18, 2005 03:13 AM
dcexplorer
18
Oct 15, 2003 10:49 AM
