clunk in front end
Old Nov 14, 2008 | 11:10 PM
transamman78's Avatar
transamman78
clunk in front end
ok, I have a clunk in the front end on both sides. replaced the shocks and the sway bar links look fine and have no play. It feels like it is right under my feet. Anyone else have this problem. Thanks for any info.
Old Nov 15, 2008 | 08:08 AM
riggz's Avatar
riggz
What year and how many miles. Any lift?
Old Nov 15, 2008 | 11:43 AM
transamman78
sorry. 03 250 ext cab 104,000 no lift.
Old Nov 16, 2008 | 01:02 PM
hangon2me's Avatar
hangon2me
Ball joint's, mine went at 65K
Old Nov 16, 2008 | 01:11 PM
69cj's Avatar
69cj
Right under your feet could also be radius arm bushings.
Old Nov 16, 2008 | 03:11 PM
kneedeep1's Avatar
kneedeep1
Kind of like a thump? Usually just when you start up?
Old Nov 16, 2008 | 07:56 PM
Blaster7Romeo's Avatar
Blaster7Romeo
now i have a thump usually after start up whether i am moving or not.. what could that be?
As for the original poster i had a random thud for a while when i was truing hard.. it turned out it was my drag link stripping the threads on the collar it connects it together. just something to check.
Old Nov 16, 2008 | 08:18 PM
sonneborn3's Avatar
sonneborn3
I have a clunk when I apply the brakes and/or hit a large bump, are these symptoms of ball joints??, I have 75xxx miles on my SD.
Old Nov 16, 2008 | 10:01 PM
transamman78
Its not the thump from the vacumn. It is on every bump I hit. Like i said I feel it right under my feet. it is on both sides. thanks guys.
Old Nov 16, 2008 | 11:48 PM
riggz's Avatar
riggz
The spring hangers are right below your feet. Maybe something's loose? Also like previous posters said check your ball joints. Raise the front off the ground and grab each front wheel/tire and try to wiggle it. If it moves its time for new ball joints.
Old Nov 17, 2008 | 05:58 AM
EOD Guy's Avatar
EOD Guy
What's this vacum thump?
Old Nov 17, 2008 | 09:44 AM
rnolloth's Avatar
rnolloth
replace the sway bar mount bushings this is what goes wrong all the time.if you un hook the links and grab a hold of the sway bar you should feel a little play in the bushing, it doesnt take much to make a ton of nopise. the dealer will need to know the size of the sway bar so they can order them they usually dont stock them.
Walleye Hunter
Jun 1, 2014 03:41 AM
MDSuperDuty
Dec 5, 2011 07:37 AM
flyer7.3
May 17, 2011 01:22 PM
fordex2003
Mar 3, 2010 01:44 PM
TrevorP
Jan 26, 2008 12:23 PM
