2003 front end clunk
Old Mar 2, 2010 | 02:50 PM
fordex2003's Avatar
fordex2003
I have a 2003 ex 6.0 that clunks going over bumps. I have replaced sway bar end links, but did not fix the problem. Now it clunks when turning left in a tight radius. Any suggestions?
Thanks
Old Mar 2, 2010 | 02:58 PM
Digger 5's Avatar
Digger 5
It could be an axle u-joint, unit bearing or ball joint.
PhoenixRisen's Avatar
PhoenixRisen
Thanks
We was the last time that your shocks were changed. Mine are cluncking right now but I can't find the part number for lifted Bilstein 5100s for mine. Take one of your shocks off and see if it rattles like a paint can.
Old Mar 2, 2010 | 03:01 PM
fordex2003's Avatar
fordex2003
Now that you say that, i think it kind of started when I put the bilsteins on. Its just gotten worse. I need to take the shock off of the drivers side.
Old Mar 3, 2010 | 12:55 PM
luxury's Avatar
luxury
Worn sway bar frame bushings can also cause a clunk. If your links were bad, I'd replace the frame bushings too.
Old Mar 3, 2010 | 01:44 PM
DaveandJennyP's Avatar
DaveandJennyP
What he said made my clunk go away.......
bull119
Jun 29, 2015 06:38 PM
Walleye Hunter
Jun 1, 2014 03:41 AM
skidooman1990
Jun 9, 2012 12:55 PM
macortiz0630
Jan 19, 2012 07:57 PM
MDSuperDuty
Dec 5, 2011 07:37 AM
