Winter driving
Old Nov 14, 2008 | 01:44 PM
97 HD's Avatar
97 HD
Winter driving
Its getting close to that time of year! Im just wondering what you all use in the bed of these trucks, if anything, for weight/traction. Around here we dont get any deep snow, IF we do get any winter precipitation its usually in the form of sleet, light snow, or ICE. Im just fishing for opinions, suggestions and ideas. Its easy to get this thing squirrely on a wet road much less ice/sleet.
Old Nov 14, 2008 | 01:57 PM
ron86toy's Avatar
ron86toy
I was trying to ****** a plate from my Dads work(GM proving grounds) before he retired a few weeks back....they had 1" plates cut out to lay on the floor of the entire bed.....weigh 1k.
I need to find something that does not take up bed space...expecting some good snow the next few days here.....first 2wd I have ever owned.
Old Nov 14, 2008 | 02:35 PM
tjbeggs's Avatar
tjbeggs
I use 6 tubes of sand. Its only really needed when I have my plow on though. Hubs are always locked and tires are siped which helps alot!
Old Nov 14, 2008 | 03:30 PM
ron86toy's Avatar
ron86toy
Where is all the Texas guys being smarta$$'s with their windows down and A/C blowin???
Old Nov 14, 2008 | 06:38 PM
wmiller's Avatar
wmiller
I use suitcase weights off of tractors. Easy to throw in and out and with just a little snow in the bed ppl walking by never know they are there.
Old Nov 14, 2008 | 06:49 PM
Cuda_jim's Avatar
Cuda_jim
I just lock the hubs and pull the lever on the floor when its needed. Does that make up for
the Texas guys not jumping in here LOL
Old Nov 14, 2008 | 07:05 PM
c00nhunterjoe's Avatar
c00nhunterjoe
i never have to weight the bed down, and we can get some good snow here, even when i go play in the fields during storms i dont weigh it down
Old Nov 14, 2008 | 07:37 PM
tjbeggs's Avatar
tjbeggs
Put a 900 lbs plow on the front and your will rethink that! With the plow and no weight in the rear i think I could pick the rear of the truck up myself.......Ok maybe not but thats the way it drives in 2wd!
Old Nov 14, 2008 | 07:43 PM
952X4's Avatar
952X4
I have a 100 gallon auxiliary fuel tank in the bed, I just keep it close to full in the winter, works like a charm.
Old Nov 14, 2008 | 07:49 PM
wmiller's Avatar
wmiller
I hear you tim they get light in a hury with a plow. Ever think of air baging the front to keep sag to a min. My springs are about wore out and am concidering buying bags rather than springs that are just going to sag all over again
Old Nov 15, 2008 | 12:39 AM
foxracing0934's Avatar
foxracing0934
X3 on that, my plow probly weighs about that much and the rear end is pretty light before the sander goes in the bed. But without anything on the front i just throw it in 4x4 and go, its been more than enough the past 2 winters.
Old Nov 15, 2008 | 08:02 AM
ckal704's Avatar
ckal704
6 tubes of sand for me as well. 4wd takes a toll on the mileage and I use it when I need it. But with a relatively short 6 mile drive to work, if I can get there without 4wd, I try to.
I do run the hubs locked for a half a day or so every month or so just to keep things spinning and lube splshed around in there, though.
Old Nov 15, 2008 | 10:05 AM
Talyn's Avatar
Talyn
You'll be fine with the 2wd and a long bed and that extended cab ron.
Sure the assend will still be light, but my 2wd got stuck less then my 4wd (in 2wd).
My grandfather never needed 4wd, he would rescue snowmobilers in a 2wd truck in the mountains here in michigan.
All has to do with the drivers.
Fords are a bit diff, cause we are light in the *** end.
I'll tell you to keep the weight out for a bit and learn how your truck handles in the snow first, then throw in the weight.
I, honestly, never put anything in my truck.
If I do need weight, I shovel snow in.
Old Nov 15, 2008 | 11:13 AM
97 HD's Avatar
97 HD
I guess I'll fill in for the texas guys, cause thats about how it is here. For you guys that get deep snow and/or plow snow I figure the weight is needed for traction in the sense of forward momentum. Im thinking in deep snow there are ruts too keep the back end of the truck behind you. Kinda like driving in mud. Here nothin deep enough to make a footprint much less a rut. The roads turn into skating rinks. Gettin moving isnt so much of a problem as stopping and keeping the back end of the truck in place. I like the idea of sand tubes and tractor weights, something that can be removed easily is a plus. How much weight are we talking pound wise?
I wish we would get some deep snow. We get "a good 'un" about every 20 years or so. Our last one that I can think of was in '86.... 12-14 inches, other than that its an inch or 2. Our greatest fear is another ice storm. We had one about 10 years ago that pretty much shut the county down for about a week. Powerlines down, broken tree limbs in the roadways, stores closed, we had no power, most had no heat (electric heat pumps here) and few places to go buy anything.
Old Nov 15, 2008 | 11:22 AM
tjbeggs's Avatar
tjbeggs
I think the tubes of sand I use are are 70 pounds, about 400 pounds total.
