Winter driving
Old Nov 15, 2008 | 11:48 AM
CampSpringsJohn's Avatar
CampSpringsJohn
I used to put concrete blocks in the back when I had a 2wd. Since I have a 4X4, I just lock in the hubs, and shift it into 4X4 when I need to. If you've got a 2wd, or a snow plow, then weight would be important. Some guys with the plows around here use bulk sand and spread it when they scrape a lot off. I would rather use sand than salt. Just my opinion. When I was a kid, my Dad would keep a half load of firewood in his pickup.
Old Nov 15, 2008 | 05:50 PM
Talyn's Avatar
Talyn
Can't do the firewood thing as often with the emerald ash borer thing going on.
300-500 lbs is plenty.
I didn't use weight in my 2wd either. Only time I put any in was my s10. It needed it, being so light.
Old Nov 15, 2008 | 06:20 PM
tjbeggs's Avatar
tjbeggs
One thing to remember with the weight is that it should be a secure load. What would happen to fire wood if you got into a wreck. You would be luck to still have a head attached to your shoulders when it is all done. Sand bags still aren't easy to secure but it can be done.
Old Nov 15, 2008 | 07:07 PM
WALJON's Avatar
WALJON
I never put weight in the box in the winter that's what 4x is for but I can see if you had a plow on it would be different story.If I did need to have weight though I think it would have to be a brand new quad runner LOL I think a 750 would be enough weight LOL
Old Nov 16, 2008 | 01:27 PM
Talyn's Avatar
Talyn
The best place to put the weight is between the wheel wells.
My father always had a box like thing that fit over the wheel wells and you could put weight in the middle. Think of 2 H's stuck together.
Also kept things in the front from sliding to the back and the things in the back from sliding to far foward.
This also kept the weight over the wheels and not from floating the front end.
Weight in my truck at the very back will float my front end a bit. its kinda fun. haha.
zhilton
Arkansas Chapter
63
Mar 29, 2015 06:16 PM
kw5413
Dec 7, 2013 05:04 PM
airjeff
May 2, 2011 10:56 AM
mark996
Feb 4, 2011 06:37 PM
66ca
Feb 1, 2011 02:11 PM
