i need help ((bad))
Old Nov 14, 2008 | 07:49 PM
andrews350's Avatar
andrews350
it runs same with out it but it is harder to start. it still has a bad miss and fills the air with a constant stream smoke
Old Nov 14, 2008 | 08:11 PM
c00nhunterjoe's Avatar
c00nhunterjoe
scan for codes, burnt wire harness perhaps? maybe get lucky and the connector came off?
Old Nov 14, 2008 | 08:45 PM
andrews350's Avatar
andrews350
i got a P0603 Internal Control Module KAM Error code
Old Nov 15, 2008 | 07:43 AM
sbxworship's Avatar
sbxworship
I would take off the valve covers and nose around a bit. I bet you'll find something unusual... Without the flames, it sounds like a bent or unseated push rod to me. I would check those out, along with your wire harnesses, inside and out. Just my .02
Old Nov 15, 2008 | 11:57 AM
tjbeggs's Avatar
tjbeggs
I would bet you are looking at a injector nozzle issue with the knocking and flames.
Fordman198699
18
Sep 28, 2016 10:05 PM
Santimanzano
Modular V10 (6.8l)
Jun 29, 2016 06:59 PM
BigBlackF-250
24
May 5, 2016 11:02 AM
Mr. Diesel 7.3L
May 10, 2013 06:24 AM
Fords&Farmalls
15
May 24, 2007 11:15 AM
